I just bought a 24000BTU spilt type inverter room air conditioner. It was installed with professional equipment and the vacum was tested. When it was first started it gave an E4 error. we reset the breaker the error went away that was 3 days ago. we tried it on heat the first day worked alright , the second day we tried the cooling it was alright, that night i put it on fan it worked all evening and night then yesterday it gave me an E4 error again . we reset braker the error would not go away. So we turned off braker today when i turned the braker back on it gave me an E8 error. what can we do i known the unit works but what is giving these error codes and what do they mean. thanks
  • Heating & Co... Master
  • 1,653 Answers
Need model number and manufacture. Likely a communication error.
Posted on Mar 30, 2017
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Posted on Mar 26, 2009
  • 116 Answers
SOURCE: is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
Posted on May 15, 2009
SOURCE: E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
Posted on Mar 19, 2010
SOURCE: Air Conditioner Error code?
I have a portable air conditioner by Airlux and todat an error code is on the display reading E5. What does this mean and how can it be fixed? thx
Posted on Jul 08, 2010
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I am installing 1.5 tonne spilt ac. I have to run condensig copper tube from internal unit till outlet. I am confused how much maximum length of cu tube can be used to have 1.5 tonn ac effective?
You need to call a professional to install your A/C system. An improper installation can destroy your new equipment and cost you lost of money to fix.
Jun 15, 2011 | Ruud UAMB024 Air Conditioner
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
I have got a problem with an lg inverter its a 24000btu/hr,the indoor is flashing six times and the outdoor unit is off,what can l do to make this unit run again?
Inverter compressor run current high. Check compressor windings all equal 1 to 4 Ohms, Check to earth 50 MOhm minimum, check run current. If it's high, or windings open circuit, replace compressor.
Jan 19, 2011 | LG Heating & Cooling
Why my ac 24000btu stop after short time
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
Aug 17, 2010 | LG LSC121PMA Split System Air Conditioner
What is the power draw (in watts or amps) of the Kenmore 5300BTU room air conditioner? The unit is being powered off the grid by an inverter, and I think the user chose too light weight an inverter for the...
5.8 amps. see page 9 (5300 btu is considered a 6000 BTU, 4800 is considered 5000 btu, sorta like a 2x4 ain't really a 2x4 LOL)
You cannot run an ac on an inverter, not enough juice to get it started.
May 28, 2010 | Kenmore Single Room Air Conditioner
Work on around 650btu per square meter.
Mar 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Will PTAC solve my problem?
Nope its a big room for 24000btu. the computation is 18sqm./ 1 ton. or 1.5 hp.
Mar 18, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
