Question about Panasonic SC-HT740 System
Panasonic SC-HT740 I have a panasonic SC-HT740 home theater system. The reciever for some reason out of the blue will turn on and freeze while "INT" is flashed across the info screen. This is normal up until now because it doesn't fulling "boot up" so to speak. It just freezes and does not shut itself down or continue on for normal use. I can manually turn the unit off and on at will, but with the same result everytime. Please help!!
In STOP (no disc)
mode, press STOP button
on the player , and 10
button on the remote
control unit.
Posted on Oct 20, 2007
SOURCE:
Panasonic home theather does not read DVD and display a U703 code
Panasonic display motor Home Theater Systems Questions ...
www.fixya.com > Forum > Tags > display motor > Home Theater Systems
Panasonic home theater systems display motor related questions and answers. Ask your ... ...getting a DVD H02 code it wont play cd's or dvd it will display the code and say stop. Is this fixable or should ... ...display a U703 code. Does I need to ...
Panasonic euromax new codes Home Theater Systems ...
www.fixya.com > ... > euromax new codes > Home Theater Systems
My Panasonic home theather does not read DVD and display a U703 code. Does I need to bring the equipment to a repair center or is better to get a new one?
Panasonic Home Theater System System Dvd u703 ... - Fixya
Dec 17, 2015 | Panasonic Sa-ht740 5.1 Channel Home...
Hi i was hooking up my panasonic home theater with the power on i heard a sound and the power came try power it up went on display f61 and then shut off what seem to be the problem model...
Never hook up theater units with the power on, you need to have the fuse replaced in your unit. You need a trained tech. for this electrical problem.
Oct 19, 2010 | Panasonic SC-HT740 System
F61 code after a speaker wire touched the chassis and sparked
You have shorted the speaker wores and blown the output amp pac. Depending upon the model, the replacement part varies from $75-$95.I don't have a listing for the SC-HT740, but the cost range should be accurate.
Dan
Oct 05, 2009 | Panasonic SC-HT740 System
SA-HT740 Broken gear
You probably can get the parts from Tritronics, but as far as I know, there aren't hard-copy manuals normally made for any of the newer products. The only paper available nowadays are the users manuals... The service manuals are on-line at Panasonic and available only to authorized repair centers. Sorry.
I'm curious - how in the heck did a gear break in the thing??? There's nothing strong enough in the drive system to do that (either the motors would sieze or belts slip).
Bugman Mark
Nov 01, 2008 | Panasonic SC-HT740 System
Panasonic SC-pt960 home theater
You must set up the Reciever manue to accept Digiatl Audio in... refer to your manual
Oct 05, 2008 | Audio Players & Recorders
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
Feb 28, 2008 | Panasonic SC-HT740 System
Sa-ht740 power problem
I have same problems please If you know anything help me
my email adress
[email protected]
thanks
Nov 08, 2007 | Panasonic SC-HT740 System
Problems with panasonic sc-ht740 help!!!
use both the HDMI ports from the DVD and Cable Box into your TV. 5.1 sound should then work if you press the AUX button. I have the same and that is how I set it up
Feb 06, 2007 | Panasonic SC-HT740 System
Panasonic SC-HT740 System Logo
179 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
