Question about Kenwood Car Audio & Video
Kenwood Face Plate Won't flip into place
My Kenwood car stereo CD player will not flip back into place. Everytime I put the face plate back on it will not flip back into place. The stereo also flips all the way around when the car shuts off for anti-theft, however this does not occur either. What should I do? It seems that the flipping mechanism is doing the opposite it should be doing. Thanks Its a Kenwood Excelon KDC-X715
  • Anonymous Feb 14, 2009
    I have the same problem. The ribbon tape between the movable faceplate bracket and the head unit has broke thru usage. Time to get a new head unit with no moving parts.
Duncan
  • 218 Answers
SOURCE: Kenwood KDC-519 CD Player
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
Posted on Aug 02, 2007
  • 11 Answers
SOURCE: kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Posted on Dec 16, 2007
hawkwatcher
  • 67 Answers
SOURCE: KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Posted on Jan 26, 2008
Eagleeyes
  • 199 Answers
SOURCE: Flip bit not working KDC-7090R
hi its going to be the flexi that connects the panel to the main pcb. you can buy a repair kit @ www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 27, 2008
SOURCE: Kenwood KDC-X711 not working
Got the same problem, try taking it out and throwing it on the ground a couple of times.
Posted on Apr 24, 2008
Stereo shut down
Did you check fuse block in the car as well as the stereo fuses?
When the face plate is down does that model have any indicator lights in the rest of the deck to see if it is getting power? My old ken wood used to have a red light that blinked behind the faceplate.
Sep 06, 2014 | Kenwood KDC-X993 EXCELON Flip-Face CD/MP3...
Protect
You have to reset your system... Use a pen to push a small button that's located in the front of the face plate. That will reset the system...If it gets stuck on standby, just push the SRC button on the face plate or on the remote..
Apr 18, 2010 | Kenwood KDC-MP235 CD Player
The motorized face plate only sits at the half-way
the flexible cable that goes from the face to the main motherboard is probably bad and needs to be replaced
Dec 10, 2009 | Kenwood KRC-X858 Cassette Player
Face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Jun 11, 2009 | Pioneer DEH-P6800MP CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Kdc 215s
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
May 07, 2008 | Kenwood KDC-215S CD Player
Face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
May 04, 2008 | Panasonic CQ-DF802U CD Player
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
Aug 01, 2007 | Kenwood KDC-519 CD Player
Shutting Off
the usual repair for a morotized face plate with symptions of no display, some buttons working or no buttons working & sometimes even the faceplay not moving, is the ribbon backthat connects the main unit to the face plate. Sometime you might be able to see the gold/yellow flat ribbon as the face plate flips. it's not too difficult to cange but it takes patience. the cables run around $15 to $30.00.if you replace it yourself, watch out incase the spring for the ribbon tension unwinds. good luck
Dec 14, 2006 | Kenwood eXcelon KDC-X679 CD Player
Car Audio & Video Logo
375 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
