Paper jam can't reach paper
I have had a paper jam in my x3580 . I have got out the paper but can still feel some inside and i can't get to it. the printer keeps saying please load paper.
  • mrninja
    mrninja May 11, 2010
    Is that a Lexmark x3580? or IBM?
  • 61 Answers
Hello
Hopefully this will help:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:595:0:0&docid=412
Posted on Apr 20, 2009
Tells me my printer has a jam but there is none
Hell,
Paper jam errors can also be caused by worn pickup rollers. When the printer tries to print a page and the rollers can not grab a sheet of paper to feed into the printer the printer will think there is a jam and display the same error. Pull out the paper drawer all the way and reach inside the top of the opening and you should find the pickup rollers. They should feed rough not smooth. If they do feel smooth then they will need to be replaced by a Canon repair center.
I hope this helps,
BuddyMc
Nov 30, 2012 | Canon imageRUNNER C1028i Laser...
PRINTER IS JAMMED SHOWING ERROR
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Paper jam p1005 hp printer
Load paper, give print command verify weather pick up roller trying to pick paper?.. >if yes check pick up roller surface feel smooth?, replace it.. >if no remove right,left and back covers, check solenoid jammed? release it.shoot print command check> if solenoid not acting replace it and verify..
Jan 09, 2012 | HP Office Equipment & Supplies
PAPER JAM - CAN'T FIND THE PAPER. IS THERE A WAY TO REACH PAPER WITHIN MACHINE?
Open the printer cover and access the cartridge area. You should be able to see the paper jam. Carefully remove the paper and avoid tearing it. Any torn paper left inside the printer could cause future paper jams.
May 01, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi, there is continous paper jam flashing light indicated at the printer (epson 600). i have checked but i found nothing jammed. i wounder i could be the reason. your support is...
Sorry - no solution, except to perhaps agree with the guy who says throw it out the window. I only wish I wasn't just on the first floor. This thing does more jamming than printing. It claims a jam when there is none. Infuriating.
Nov 06, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
WILL NOT PICK PAPER SAYS PAPER JAM
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Aug 17, 2010 | Dell 924 All-in-One InkJet Printer
Paper jam in fax how do I clear?
folow the instruction
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    Paper stucked inside
    Open the top cover.
    Pull out the toner / developer units and look for paper under neath.
    In the rear, pull open the access door.
    remove the paper tray and look for misfed paper.
    Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
    It keeps saying paper jam why? it is not jammed/
    Paper jams are reported under two conditions.
    1) Paper reaches a sensor and never leaves it.
    2) Paper does not reach the sensor in the time allotted.
    A simple test is to put a mark on the next page that should be pulled from the paper tray. If the paper is pulled from the tray, you will find it inside the printer. If the paper fails to feed, it will be sitting in the tray where you marked it.
    Don
    Dec 12, 2009 | Kodak EasyShare Printer Dock Series 3
    Computers & Internet Logo
    66 people viewed this question
    David Payne
    David Payne
