Question about NorStar (NTDU76BB34) IP Phone
The Forward key is not available anymore on my Nortel NTDU92 company IP phone and I really need it to be activated. Can you phelp please
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Nov 23, 2012 | NorStar Meridian M7310 Phone
How to forward call to another phone
Press feature soft key (first button under display panel) and the 4.
In order to cancel call forward press feature key, # key, 4.
Jun 23, 2012 | Nortel Business Series Terminal T7208 -...
Directory key = "no application available", need to store phone #
You need to configure your CS 1000 for Personal Directory / Redial List / Callers List through Element Manager. Instructions for doing this are in the IP Line Fundamentals NTP. You can download the NTP from www.nortel.com/support.
Mar 23, 2009 | Nortel i2004 IP Phone
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Dec 18, 2008 | Nortel 1140E
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
Problem with Nortel WLan handset 2210
must drop the whole programing and start from scratch. it called dumping.
Feb 14, 2008 | Computers & Internet
Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Jan 10, 2008 | Nortel 1140E
Problem with IP phone Nortel 1120E
Try to reset the bandwith of the phone by using the nortel software.
Jul 11, 2007 | Nortel 1120E
NorStar (NTDU76BB34) IP Phone Logo
459 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
 Brian Main
Brian Main
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
