Question about Magellan RoadMate 700 GPS Receiver
Loss of signal
Well its like this,after turning it on it will work for maybe 15 mins and then it will freeze up or have me hundreds of miles away from where i am or sometime it has me going 180 mphs! It seems to get hot so i guess its the HD, i have taken it apart and the antenna seems fine and this will happen with my external antenna also..thanks
I have the same problem(and others too)
After it freezes, I have to turn it off and turned on again. Sometimes it works. I think, that these problems can be fixed only in repair shops (Dealers) only, prohabs that's the whole idea...
I paid over $1,000.00 when it came out. I wouldn't pay for it $200.00 if I would know.....
There are units on market today, that cost less than $200.00 and do better jod than Magelan 700!
Good luck! drj.
Posted on Jan 08, 2008
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
DVR-R10 stops recording with 10-15 mins left
If it's your cable box DVR, you need to call your cable provider to reset your cable box.
Apr 16, 2014 | Directv R10 TV Receivers and DVRs
I have cobra 25 ltd and i,m picking up signals from hundreds of miles away can i tune it down to pick up more locally
Try turning down the RF gain. It is the 2nd knob to the left of the channel selector. This will limit skip stations and receive only local higher signal stations to come through. Do not turn it too low or you won't hear much of anything. Hope it helps.
Oct 01, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
AC Problems & Melted Overflow Tank
Trust you mech on this one.
Jul 09, 2012 | 1999 Acura TL
Sir maptol rice cooker not working problam was we on power plug and push on button after 10-15 min automatically button was off.
that means over heating, maybe loss connecting,, be sure the power you've use not excess to 230vac if voltage is ok, maybe thermistor problem,.. OR bring your Unit to the nearest qualified technicians.
Aug 08, 2011 | Kitchen Appliances - Others
My 2001 vw passat's a/c runs great for 15 mins at first start up of the car. After that - no cold air but the blower still blows. So if I dont have any further to go than 15 mins. Away im okay. What could...
Maybe there is a restriction where the r134a refrigerant flows. Or, the refrigerant is low on charge and shuts the compressor off due to this.
Good luck to you.
Jul 01, 2010 | Cars & Trucks
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
RCA DTA800B1 converter box - Works great for 15 min. then quits.
I would suggest to return it because it should work as intended without dropping the signal.
It would be a good idea to add a signal booster to keep a good signal strength.
Mar 31, 2017 | Televison & Video
TV keeps turning off.
could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Dec 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
