Question about Apple iPod nano
Remove security code
My six year old son accidentally put in a security code into my ipod but does not remember the numbers how can i fix this so i can use again
  • damn Sep 20, 2007
    tried all you said did not work
  • damn Sep 20, 2007
    There is a key showing in the top left corner i am unable to use the main menue
  • 150 Answers
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Posted on Sep 20, 2007
  • Anonymous Sep 20, 2007
    Okay, try this
    see the last part
    Updating and using your iPod Screen Lock
    The screen lock feature allows you to lock your iPod so that others cannot access it. Choose ?Extras? from the iPod's main menu, then scroll down and choose ?Screen Lock?. If this is the first time you're using the screen lock you will first need to set a combination. Select this option by pressing the 'Center' button. Scroll right or left on the click wheel to increase or decrease the numbers then press the 'Center' button again to move to the next field. Once you have updated all the fields with numbers, press the 'Center' button again to leave the screen.
    The option ?Turn Screen Lock On? should show up on the screen. Select this option and choose ?Lock? from the next screen. The lock will be displayed whenever you pull up the screen. You will need to enter the code to open it.
    Repeat the steps each next time you want to activate the lock. You don?t have to choose a new code each time. If you enter the wrong code, the numbers will flash and you can try again. If you forget your combination, connect your iPod to your computer, and iTunes will unlock it for you.
SOURCE:
Want to give my dad my old phone, when i put a sim into it, it came up security pin. i can't remember the code i used to use?
Take it to the retailer the service is through. They will install a new sim card and give him a new number for it.
Oct 19, 2009 | Nokia 6170
My son has accidently put the screen lock on my daughters ipod nano & she can't remember the 4 digit code. Help!
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Oct 01, 2009 | Apple iPod nano
Security code on nokia 6555
Hi Friend,
From the below link u can get the security code by providing your IMEI number,to get the IMEI number u must just *#06# or at back side of the mobile u will have serial number is as same as IMEI Number,
http://mastercode.nokiafree.org/
Regards,
Ayyasam
Jun 06, 2009 | Nokia 6300 Cellular Phone
Locked ipod cant remember combination
"Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize."
Cite: http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-reset-code-to-unlock-screen.html
May 30, 2009 | Apple 160 GB iPod Classic (Silver) +...
Ipod nano security code
Try this:
  1. Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
  2. Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  3. Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  4. Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
http://www.ehow.com/how_4793090_unlock-ipod-nano-code.html
Apr 01, 2009 | Apple iPod nano 3rd Generation
Ipod security code
Hey,
I've posted the solution here
http://www.fixya.com/support/r561879-code_forgot_code
if its just the volume code then see the link on the end of the solution in that page
Let me know if you need anything else.
Thanks,
Ekse
Jan 31, 2009 | Apple iPod nano
Locked iPod
Use Itunes, and Restore to factory settings. this will remove any lock codes. It will also erase any files currently on the Ipod (Music or otherwise). Then just Resync with Itunes, and you should be back in buisness
Aug 19, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod security code
You can unlock your iPod nano in two ways:
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
â Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Jun 26, 2008 | Apple iPod nano
Eep... Maybe not the solution you're looking for, but the only one I can think of would be to run a restore through iTunes. If you need help with that, check out the following link:
http://docs.info.apple.com/article.html?artnum=60983
Good luck! And next round, punch in a code of your own.
Apr 07, 2008 | Apple iPod MA446LL/A MP3 Player
to reset switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
Feb 10, 2008 | Apple iPod nano
Apple iPod nano Logo
228 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
