Question about Briggs & Stratton Garden
Briggs & Stratton LR2107C Jonsered Lawnmower
I wonder if you can help me. I have overfilled it with oil and cannot find the oil drainage plug. I bought this 2nd hand from a dealer and he promised me a manual would follow, however, it has'nt arrived. Can you help with a solution and a manual please.
jgwhomeequip
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
  • 246 Answers
SOURCE: Looking for a Manual
Hello:
Power Kraft is an MTD Product.
You can Contact MTD at 1-800-269-6215 at during the following times: Monday-Friday 8am-5pm and Saturday 11am-3pm EST. (SEASONAL HOURS MAY VARY).
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 41 Answers
SOURCE: my briggs and stratton 550 series lawnmower will not run
Could be float in carb.sticking.Take carb off & apart.Put float in water to see if it floats.Check float by shaking next to ear.If you hear any sound,you need a new float.
Posted on Aug 29, 2009
Iput to much oil in a briggs and stratton engine on a wood chipper the engine has seized up what can i do
Drain out the oil, take out the spark plug and see if you can get it to turn. Turn by hand or wrench not an electric starter
Aug 28, 2013 | Briggs & Stratton Briggs Stratton...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
How do you drain oil from the tank?
Hello there:
if you clean the under side of the deck where the blade is at you will find a small plug about a 9/16 in size this is your drain plug for the engine ok?
Hope this is very helpful for you
Best regards MIchael
May 30, 2010 | Briggs & Stratton Briggs Stratton...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
162 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
