Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba 42H82 convergence problem
Blue and yellow shadowing at bottom of screen. Blue convergence alignment: No movement downward in the Circumference Convergence settings. The red adjustments worked perfectly.
  • 1 more comment
  • Anonymous Mar 07, 2008
    I HAVE THE SAME PROBLEM , I THINK IT IS THE CONVERGENE GOING BAD , I TRY THE TOUCH FOCUS BUT IT DONT HELP . TV IS 5 YEAR OLD , THE REPAIR MAN SAID IT WOULD COST ABOUT 350.00 TO FIX IT , SO I DONT KNOW IF IT WOULD BE BETTER TO BUY A NEW ONE, ALSO IT IS A WIDE SCREEN .IT STILL LOOKS GOOD , HELP .
    I AM HAVING THE SAME PROBLEM WITH MY 42 WIDESCREEN TOSHIBA , , THE PICTURE IS YELLOW AND BLUE AT THE BOTTOM OF THE SCREEN , I HAVE TOUCH FOCUS , BUT IT DONT HELP . I WAS TOLD IT COULD BE THE CONVERGENCE GOING OUT , IT IS 5 YEAR OLD , THE REPAIR MAN SAID IT COULD COST 350.00 TO FIX IT . AND IT MIGHT HAVE 2 , INSTEAD OF ONE . IT IS STILL A NICE TV ,
  • radiohead258 Jan 01, 2009
    well the tv i have its the 42 inch projection from toshiba and the focus is all messed up on it like the red the green and the blue it show instead of one person it shows like 5 or 6 and its all wierd and blury and i dont know how to fix it i tired to mess with the projector lamps but didnt help to much just a little bit
    Genius:
  • 1,694 Answers
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Posted on Sep 29, 2007
6ya staff
SOURCE:
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 12, 2011 | Toshiba 42H82 42" Rear Projection...
My Hitachi has a blue and yellow swirl band at the top and bottom of screen
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes.Than the tv convergence board is dead.The tv convergence board must be replace 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Hitachi Televison & Video
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H82 Blue raster is bowed to the right in the middle to the rt. The auto convergence give an error.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 16, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Blue Convergence on Toshiba 42H82 42-Inch
it should just need new STK392-110 ICs which is actually not very difficult. You will need two ICs both STK392-110 and you can get replacements at the following link and they provide instructions on how to remove and replace Convergence ICs.
Heres the link.
http://servicemanuals.vstore.ca/
Oct 22, 2008 | Televison & Video
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
567 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
