Question about Car Audio & Video
CDA-9812RR not keeping its settings
Hi There,
I have just installed a CDA-9812RR in my Toyota Celica. I am having problems as the stereo does not hold its settings when the ignition is turned off. Meaning I have to play with the Bass everytime i turn the engine on.
Any ideas?
Cheers,
Gaz
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You need to make sure the yellow lead is hooked up to a constant power source.
Posted on May 01, 2009
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
Im trying to install an aftermarket stereo and need to know what wires to connect. need wiring diagram for 96 toyota celica gt stereo harness>
you can purchase a wiring kit that plugs into existing factory wiring for about 20 bucks saves alot of time and trouble
Sep 13, 2009 | 1996 Toyota Celica
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
1983 toyota celica wont hold charge
Be sure that your stereo is okay. Couple of times the stereo goes bad not that it won't work well but the stereo will be shorting the power on the battery whenever the car is idle.
Good luck.
rate this
Apr 07, 2009 | 1983 Toyota Celica Supra
Alpine cda 7893 no sound
this radio does have setting to turn off internal amp go into menu and check it hold down set button to access menu I think
Nov 20, 2008 | Alpine CDA 7893 CD Player
How do i control my ipod through my alpine cda 9812rr head unit??? i cant seem to browse through any of my albums or artists names at all using the headunit!
before u connect it to ur cd player go to the songs u want to hear and then plug it in then go to aux on ur cd player and it should work,. hope this help
Nov 17, 2008 | Alpine Car Audio & Video
Celica stereo
are stereos known to be good. try buying wiring kit for use in your application.
Oct 27, 2008 | 1992 Toyota Celica
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
Alpine Ipod/Stereo Error 1 message
my alpine cda 9856 only displays that message when my ipod dies. so your ipod pobably dies then the head unit recharges it enough in the time your resetting it that it can play again. :)
Nov 26, 2006 | Alpine CDA-9857 CD Player
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
