Water Dispensing & Filtration Logo
Maggie Ray Posted on Sep 24, 2013
I made a water level at home but it is really hard to read because the water is clear what can I do?
roi shesh
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Contributor 24 Answers
  • Posted on Sep 24, 2013
roi shesh
Contributor
Level 1:
Mentor:
New Friend:
Answers
24
Questions
14
Helped
16669
Points
89
Have you tried adding a little food coloring to the water? Just enough to make the water have color you don't have to go crazy and make the water a dark color.
Reading hot but motor is cool
Check to see if you have water/coolant in the system. If the water/coolant level is really low, the radiator will feel cool and the water temp guage will read hot because it's reading hot air instead of water. If you are very low with water, there's a leak somewhere in the system.
Samsung fradg
When you thaw or let the ice melt, make sure all the vents between the freezer(upper compartment) and refrigerator(lower compartment) are clear of ice or obstructions. This is very important! Make sure all vent ducts and tubes are clear of ice!!! Next Level the unit front to back and side to side. Make sure the refrigerator is level. When level the doors should close without assistance. It is normal for water build up and dripping sound in the fridge do to condensation, the air vents and an evaporation pan located behind the cover in the rear of the freezer will eliminate the water if unit is properly leveled. I had the same problem, then i read the user manual. this will also eliminate all the water in the lower compartment.
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Have a Pentair 7000 water softener, getting brown/gray water in my home! Any suggestions
I think this can also be due to rusty pipes or connections as it is seen to clear off after the initials flow. You can connect an online filter unless the water is confirmed to be hard and needs to be softenend..
Low level of rinse water. What can I do?
Possible that the water level sensor has failed and so it does not load to the level set by the program. You will need to check the level sensor to clear the water line of air block or dirt or faulty unit.Try to set a higher water level to the program settings and see if the water fills up on rinse, choose an different program
1helpful
Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
May 15, 2010 • Plumbing
1helpful
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
Washer machine over flow at start up
Hi There
I have this for to read and hope this gets you in the right direction. Let me know how it goes.
Thank you for writing to fix ya.
Water level not right
There is a water level switch on the machine. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or replace the water-level switch (easy to do it). Good luck !
Top Water Dispensing & Filtration Experts
Steve Pack
Steve Pack
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Larry
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
