Question about Kenmore 46462 Front Load Washer
Kenmore 464642 Front Load Washer is causing towels and clothes to smell mildewy
What would cause our Kenmore 46462 Front Load Washer to cause our towels and clothes to smell really mildewy? We have wiped out the inside after every washing. We has removed the clothes immediately after every washing. We have tried different cycles and different size loads without any luck. Is there something we are missing to do or a setting I should look for in this situation?
  • 209 Answers
Just start with cleaning out the pump and the pipes that connect it both to the drum and the outlet, check the outlet on the wall that it is clear, given the info you have this sounds like that the pump is not clearing all the water in time and filing up with some old water left in the machine,, clear out these pipes with care and you should be fine, check the pump pushes out the water with sufficient force work safe unplug when working on appliances, electric and water don't mix hope i have helped, if so rate me please
Posted on Sep 19, 2007
My washer has a mildow smell and my clothes smell musty, especially towels!
This is a comin in all front loaders. It it caused by two things not using HE soap and keeping the door closed when not using it. The only way to get rid of the smell is to run 3 to 5 cycles with bleach and no clothes or use a washer cleaner. Most large hardware stores carry them. Once the smell is gone be sure to leave the door open when you are not using it and wipe out the gray boot(gasket/seal) after using.
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Nov 24, 2009 | Electrolux EW1000i Front Load Washer
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Clothes and towels don't smell fresh after washing
If you are sure that the pump is not blocked then try running the machine on a quick wash on its own with a little bleach in the drawer.
Jun 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Filter cap
Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
remember "left is loose, right is tight. So turn it counterclockwise. It will require some strength or a channel lock tool.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Feb 03, 2009 | Kenmore 46462 Front Load Washer
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Spins very slow on rinse/drain and spin
Your filter &/or pump could be blocked. Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
Jan 20, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
119 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
