Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side dirty water
I install a new water filter after a year except I forgot to turn it when I ran the 3 gallons of water through it. I did see no problem with the water. However, when I did turn after running the water through it, it now always seems to have a film of something floating in the newly dispensed water. What do I need to do. I have run about 20 gallons of water through it and it still has the problem. Is it a broken membrane in the filter and I need a new filter(thought I read that somewhere)?
    Problem Solver:
  • 17 Answers
The original cap for the filter, was supposed to be a plug bypass, for application of outside undersink filter. Using, this, one can check to see if the filter was the contaminant here. You need to be, more specific, to explain a problem. Something is too too generasl,,, color, consistancy, odor, quantity, filter has a fine fine filtrationl unit on the outlet, and if defective the charcoal residue may come out. You can remove filer and pass suppy water thru and review the effluent coming out. ??? Regards, fmauka
Posted on Sep 22, 2007
SOURCE:
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Locate fuel pressure pump on 1985 ford ltd
maybe 4 gallons is not enough in that big tank I would consider say another 20 gallons before I looked for more problems
Jan 12, 2014 | 1985 Ford LTD
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Whirlpool Side by Side- semi-translucent tape likedebris in water
Sounds like the plastic from the icemaker is chipping off the unit in the ice making process.
If your water is running clear except through the refrigerator that is my suggestions. Although normally the plastic color is blackish.
Jan 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
the problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Filter ejection
it shoulnt eject they are usally screwed on
Dec 14, 2007 | Kenmore 50522 / 50524 Side by Side...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
