Question about Sony PlayStation Portable (PSP) Console
I want to connect a cctv camera to psp
I want to use the psp as a test monitor for cctv, i have been told you can do it throughthe usb can it be done?
  • paulworthing May 11, 2009
    please dont forget the external cctv camera has 1 volt peak to peak on video out and has only 2 conducters , i was hoping someone would have the wiring diagram so i can cut a usb to mini lead plug in and use the right conductors on the usb lead
  • 107 Answers
Yes indeed. you need simply a usb to mini usb hub cable ( about 15 bucks) and hook it in, go to usb mode on the psp it will have a few options. naturally th epsp wont recognize the system immediatelt, so give it time and all will be solved. if this doesn't work, then i recommend changing psp settings on your computer to allow the psp tpo recognize it immediately.
Posted on May 11, 2009
3 Suggested Answers
issy2
  • 460 Answers
SOURCE: PSP NOT CONNECTING
You are not describing your problem clearly, Please be clear. It looks like your problem statement is in complete.
Hoping to hear from you soon.
Thankyou
Posted on Apr 20, 2008
NinjaUK
  • 164 Answers
SOURCE: usb connection failure
This is usually a problem that involves a fault in the USB cable. My suggestion would be to try a different USB cable and if that doesn't help try using it on another computer as it may be a fault with your USB port.
Posted on Sep 05, 2008
Can the exsisting protacal be modified?
Good question. What camera? Most cameras cannot be modified. Some newer cameras are multiple protocols. Need more information.
Sep 25, 2014 | CCTV Camera Pros MON-LCD35P Test Monitor...
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
HOW TO USE DSC-W650 AS WEBCAM
use the USB cable to connect the camera to the PC .PC also has audio video out cards to be connected to the TV monitors.
The CCTV cameras are cheaper and easy to connect as they all come with Audio Video out.
Feb 26, 2014 | Sony Cyber-Shot DSC-W560 Digital Camera
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
IS IT POSABLE TO CONNECT A CCTV CAMERA WITH NO P.C.
Sure. There are many CCTV cameras that can be connected by RCA cables.
Feb 03, 2013 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Sony PlayStation Portable (PSP) Console Logo
142 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
