Question about Acer AL1713 17" LCD Monitor
Acer AL1713 flashing power LED
My AL1713 doesn't work; power-LED flashes on and off every few seconds. No backlight.
I did measure power inside, and 5V/12V switches on and off all the time.
After disconnecting the power board from the other boards power is stable and OK.
I have schematics of AL1701, but AL1713 is different
Who has a AL1713 schematic, of know what could be the cause of this error?
  • guiribal Apr 29, 2009
    I have the same problem, anyone can Help? Please.
    Pedro
    Habit-Forming:
    New Friend:
  • 28 Answers
http://www.lcd-television-repair.com/1-Acer.pdf
Hi
Check out above link for AL1713 schematics and service guide.
Based on your explanation it seems you have some shorts problems with the other board.
Posted on Aug 15, 2017
3 Suggested Answers
  • 36 Answers
SOURCE: No backlight. I'm looking for a schematic for the
<p>How about the whole <A href = "http://www.go-gddq.com/upload/2009_06/09060313346662.pdf">Service Manual</a> ?</p?
Posted on Jun 17, 2009
Mark Harmer
  • 8 Answers
SOURCE: Power-on LED AL1916 acer LCD screen doesn't work, no display
Hi - I've just fixed ny AL1921 which would be similar to yours internally. There are a couple of issues which are common:
Bad soldering around some of the copper coils (insulation may not have been properly stripped and leads to intermittent connection and (much more likely)
Blown electrolytics.
If you have ANY electrolytics on the main board which are swollen at the top or have electrolyte oozing out of them at the top or where they meet the board, then replace them.
My ACER started flickering and switching off randomly (no power light on the front either) and I though the power supply inside was toast. However, I found two electrolytics on the large power board (1000u / 16v) which had a black crust at the top. I replaced these and the monitor sprang back into life. Try to use replacements which have a temperature rating of 105 degrees C. Basically I think these things give out just after the guarantee runs out.
Hope that works for you.
Posted on Sep 21, 2009
Why does my acer aspire e1 571- 6482 not start or charge anymore? only the on led and batt led flash.
pressing power on button should be for 30 to 40 sec but the flashing lights means there is a hardware problem can find flashing light codes on the net you could try removing ram 1 by 1 c if that works hope this helps if not will keep an eye on this
Jul 29, 2014 | Acer Aspire E1-571-6650 Laptop
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 10, 2010 | Acer AL1706AB LCD Monitor
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, when powering up the light will turn yellow, them the t.v powers up and can hear sound but no picture, and then hear a click and light flashes green.
First turn on,do the power LED light stable?Few sec.Power LED and LED OPC flashes?This very common on Sharp tv,tries power off/on at 4 or 5 each time it flashes,well power up have backlight on and it work.After this doesn't work than ur Tuner Signal board it dead.
Feb 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Acer al1713 monitor and the power led flashes form yellw to green
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Jan 01, 2010 | Acer AL1713 17" LCD Monitor
Aug 17, 2009 | Acer AL1713 17" LCD Monitor
Take the monitor apart, and replace any swollen electrolytic capacitors. If that doesn't help (and it probably will) then check for bad soldering and resolder any joints.
But if the capacitors are swollen that will almost certainly fix your issue.
Jun 08, 2009 | Acer AL1713 17" LCD Monitor
Acer AL1713 17" LCD Monitor Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
