Question about Toshiba Satellite M35X-S149 Notebook
I have a Toshiba 35x-s149 laptop. Screen went
I have a Toshiba 35x-s149 laptop. Screen went black. However if I put an aux screen into the back of the laptop it works find. Using F5 I can toggle back and forth but Laptop screen does not come back on. I have replaced the LCD but have the same problem.
  • Anonymous May 04, 2009
    Screen went black - plubbing in remote monitor works great.
  • 44 Answers
My Toshiba satellite M35X-S149 shows the lights and can hear it running but there is no display on the computer monitor
Hi oysertails...
Try hooking your laptop up to an external monitor...if you can see the picture on the external monitor then your lcd screen may need replacement or the lcd inverter board.
Please take time to rate me
Sep 24, 2011 | Toshiba Satellite M35X-S149 Notebook
Hello, When i turn my computer on the screen clearly turns on however there is nothing on it. It is just black but that sort of off black that is lit up. It makes some sounds as if it is doing something...
Hello !
Connect an external monitor and if it works, your problem is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 28, 2010 | Toshiba Satellite M35X-S149 Notebook
My screen is black on my toshiba satellite m35x-s149 laptop. What do i need to repair this? I currently use a desktop monitor to see but would like to fix and use the laptop as it should be use. Any...
If you are getting display in an external monitor, it means Laptop is working fine except LCD. Better to replace the LCD. It will not coat you much. Contact Service center or Computer accessories dealer, for used LCD, they used to have from old PC.
Aug 20, 2010 | Toshiba Satellite M35X-S149 Notebook
My Toshiba Tecra M4 losses power and switchs off.
first to do is check the HDD RAM,or the wireless card,,
Jun 25, 2010 | Toshiba Satellite M35X-S149 Notebook
My laptop will turn on but the screen is black i need helpp
Turn off pc, remove battery, press and hold button for 5 seconds, put back in and turn back on. If the memory card stick isn't bad, then this should work just fine.
Nov 12, 2009 | Toshiba Satellite M35X-S149 Notebook
I have no display on the screen. Its black.
This issue is usually of of 3 things...
1) the internal cable has come loose on the LCD inverter or motherboard
(need to open the laptop up by a trained tech)
2) Backlight buld is bad (look at the screen in bright lighting... can you see the image of the windows desktop there but very dark?)
3) Bad motherboard (must be replaced)
best of luck,
Sagacious1
Aug 07, 2009 | Toshiba Satellite M35X-S149 Notebook
No picture on screen
Check your power settings:
On Vista:
go to Control Panel
click on "Mobile PC
click "Power Options"
Depending on which one is highlighted check on its "Change plan settings" and check time on "display" and "sleep" options.
Adjust settings per preference.
On XP:
Click on Start>
Click on Control Panel>
Click on Power Options>
Check "Power schemes">
Select "Hibernate" tab and check settings
Jan 11, 2009 | Toshiba Satellite M35X-S149 Notebook
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
M35X Screen went black and will not come back on after shut down, reset and power up
Try to connect to external monitor and see if you see anything. Of course when you do that you have to hold at the same time fn key and the key that has a blue picture of computer screen.
Jan 17, 2008 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite M35X-S149 Notebook Logo
206 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
