Question about Sony PFM-500A2W 42 in. Television
Service code 99 fans start and stop then stays on standby
Th fans start then stop three times but then stays on standby it shows service code 99
    Problem Solver:
  • 8 Answers
Code 99 leads to a defective powersupply unit !!!
Replacement is very expensive ;-(
Arround the € 550,00 / $ 650,00
Best regards , EuroNet 2000 The Netherlands
info@euronet-2000.nl
Posted on Aug 29, 2009
Panasonic TH-L19x10mk rapidly flashes green then stays green for a couple seconds then starts flashing red got into the 40s before I stopped counting the screen flashed for a split second
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Type in the brand name of your device, [here it is "Panasonic"]; in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 12, 2015 | Panasonic Televison & Video
I have a 99 saturn sl, my engine fan keeps going out cant pass service light on
I believe that the reason that your fan is staying on,and causing the fuse or fan motor to go out,is because you have an overheating problem. Which could be several things....water pump,radiator,thermostat,or blown head gasket.I would have the whole cooling system checked first. Secondly,where are you buying the fan motors at?
Sep 29, 2012 | 1999 Saturn SL
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Only comes on for a second power light blinks red 4 times, stops then repeats
4 times standby red light blinking is an error code that shows that Fan problem in tv. Check following possible causes of that problem in tv:
1- Fan 1-4 power is not supplied. (AGU board).
2- Fan caught wires or harnesses.
3- Fan connector is not attached securely.
Thanks.
Jul 23, 2010 | Sony KDF-E42A10 42 in. LCD Television
Jvc th-c50 home theater standby light blinks but won't turn on
you need to have service manual copy to check amplifier output section as it seems defective. There are few websites that offers service manuals download for small fee.
Jun 11, 2009 | JVC TH-C50 System
Service code 51,52,53,54,55,99
The Sony will turn off or won't startup !!
Code : 51 ... 52 ... 53 ... 54 ... 55 indicate to the group of fans on the back side.
When recieving all numbers 51 til 55 means that NONE ofn the fans are functional.
result of this four codes will be that Code 99 show up , and turn off your sony.
Findout what corses the problem with the fans and code 99 will removed allso.
Jun 06, 2009 | Sony PFM-500A2W 42 in. Television
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Asus Laptop freeze after starting
if the fan does not work... don't use the computer till you replace the fan with one that is working.... a good chance you will burn out the cpu. usually thermal shutdown occurs when the cpu gets too hot... you may also want to consider purchasing a notebook cooler....
Robert
Dec 17, 2008 | ASUS m6n Notebook
Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Nov 26, 2008 | Panasonic TH-42PHW5 Television
Sony PFM-500A2W 42 in. Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
