Question about Toshiba 32A41 32" TV
My TV is acting up!!!
It started today that the television will go up (to the max) or to the lowest volume level without touching the remote. Also it will not turn off when this happens. I tried unpluggin it for a while but it still did the same.
  • scrc Nov 07, 2007
    My Toshiba tv is doing the exact same thing with the volume going louder (to 100) and softer (to 0) on its own. Also the screen display for the volume stays on and then I can't turn the tv off or change chanels or change the volume until it decides to go off on its own. I have unplugged the tv for several days to try to reset it as recommended by the Toshiba rep and that worked for a short while as long as I unplugged the tv every night, but now that doesn't work any more. What did "My tv's acting up" do to fix his problem?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
There might be a failure of components connected to ground ckt in sound sound section check print near switch & volume control for loose or dust.
Posted on Sep 19, 2007
  • 67 Answers
Clean the softouch button up and dwn use soldering iron. remove the switch button use blead fulout the ruber. clean a little screw inside the switch button and assemble the switch. use the iron to fix the 4 side of the switch(small switch)
SOURCE:
LG Television 32lh5000 I have started getting a problem with this TV. When I try to change the volume I press up or down on the remote control and the volume just continues to change without stopping...
Change the batteries in your remote, this is a common issue with batteries that are low on charge.
Also if you find that your TV intermitently changes channels and no one is even touching the remotethis is the same problem.
Aug 13, 2011 | Televison & Video
Seems like some type of control board problem. Remote will not work on tv, but works other devices. Manual controls are squirelly. Cannot change inputs. Can move to other inputs on menu but when I hit...
Thats a bad button on the front keypad of the tv . The remote does not work because the tv micro sees a button pressed all the time and never listens to the IR reciever . If you pull the front speaker grill off you will find connector ZF just below the keypad or just inside the access panel. If you do remove that panel don't touch anything else.Just follow the wires down from the keypad to connector ZF. Connector ZF is inline with the wires to the front keypad. Unplug it . Then remote will work like normal. Use it like that or have the front keypad buttons replaced.
Oct 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The volume will automatically increase until the
YOUR VOLUME BUTTON MYBE STICKING I NEED TO KNOW THE MAKE AND MODEL ON TH TV
Aug 24, 2009 | Televison & Video
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Feb 26, 2009 | Samsung Remote Control
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Volume using remotes either ramps to max or all the way down
Go into the service menu and reset the main board.
Jun 26, 2008 | LG 37LC2D Television
LG Volume to 100 by Itself - will NOT respond to remote
It's hard to diagnose without a model, but, given the problem I would say it is a 42LC7.
If it is, then, it needs a modification in the main PCB. We used to jumper coils at first, now we have to change the main PCB.
It's less than a year old, it's under warranty.
For a servicer in your area that makes house calls:
Contact LG at:
(800) 243-0000
If you have any questions, reply to this post and I will respond.
Dec 15, 2007 | Televison & Video
Volume increases to max, screen blinks, remote becomes useless
All I can offer as help is to disconnect the TV from the mains power completely and go away and leave it for an hour or so or even overnight. Then plug it back in and possibly it will behave itself again. BMW
Jun 07, 2006 | Mitsubishi WT-42311 42" Rear Projection...
Toshiba 32A41 32" TV Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
