Question about Clarion M235-RET CD Player
Clarion M235 I purchased a refurbished Clarion M235 and it will not load CDs. The radio works good bur after a minute or so, it ejects any cd I try in it. tried five cds and it was always the same thing.
  • 752 Answers
It needs a new CD mech. Hopefully you can exchange it from the shop you got it from.
Posted on Sep 22, 2007
Radio will not power up when I pust power button.
Make sure you have power going to both the red and yellow wires. If power is going only to the yellow wire, it will eject cds, however both the red and yellow wires need to have voltage going to them in order for the radio to work.
May 29, 2012 | Clarion XMD3
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
Ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
May 11, 2009 | Car Audio & Video
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Apr 08, 2007 | Clarion CDC1235 CD Changer
Clarion M235-RET CD Player Logo
216 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
