Question about Sony PFM-500A2W 42 in. Television
It shows a service code of 99 - Sony PFM-500A2W 42 in. Television
    Problem Solver:
  • 8 Answers
Code 99 leads to a defective power supply !!
A replacement is very expensive ;-(
Arround the € 550,00 / $ 650,00
Try to let repaire the power supply unit.
Best regards , EuroNet 2000 The Netherlands
info@euronet-2000.nl
Posted on Aug 29, 2009
Rinnai code 99
i am not an expert. this is how i fixed my rinnai code 99. my rinnai 100 4f would run for few seconds then the red light would continue to flash. code 99 would come up.i took the unit out of service. i notice that the fresh air hose had two very small hoses located on it's elbow had been switched around when i took it to be serviced. the unit worked well. how ever. i changed my mind when i realized the service was not need. anyway the two small hoses on the elbow one office is larger than the other and they must be put on the correct one,i switched them around the unit flamed up. and now i have sweet heat again.no code 99.
Dec 17, 2016 | Rinnai Heating & Cooling
Show me a 99 show me 99 Jeep Grand Cherokee pictures
yes, goggle is your friend (click that then click images on top)
amazing, no?
https://www.google.com/webhp?gws_rd=ssl#q=1999+grand+cherokee
the book is free, too LOOK at, , no pay ! ;like spam above.
the FSM, factory service manual , click body.
99 is WJ (in usa, are you>>>???_
click body, 191 pages, no less.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
posted over 300 times same answer.
Apr 08, 2016 | 1999 Jeep Grand Cherokee
What does fault code 99 indicate?
What? 2days? Call the installer! or seller. Could be a gas supply safety problem!
Mar 24, 2012 | Maytag Neptune MDG6800 Gas Dryer
Kdc-c517fm. shows 99E and will not release disc holder
From the Kenwood manual:
Something is wrong with the disc magazine. Or the unit is malfunctioning for some reason. 99 E: Check the disc magazine. And then, press the reset button on the unit. If the "99E" code does not disappear, consult your nearest service center.
I hope the rest works for you.
Feb 28, 2011 | Kenwood KDC-C517FM 10-Disc CD Changer
Code p0230 shos up on my 99 Mercury Sable. I just
That code is: Fuel Pump Primary Circuit Malfunction. Could it be the wires are not on tight or one is shorted? Check wiring very carefully.
May 19, 2010 | 1999 Mercury Sable
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Service code 51,52,53,54,55,99
The Sony will turn off or won't startup !!
Code : 51 ... 52 ... 53 ... 54 ... 55 indicate to the group of fans on the back side.
When recieving all numbers 51 til 55 means that NONE ofn the fans are functional.
result of this four codes will be that Code 99 show up , and turn off your sony.
Findout what corses the problem with the fans and code 99 will removed allso.
Jun 06, 2009 | Sony PFM-500A2W 42 in. Television
Service code 99 fans start and stop then stays on standby
Code 99 leads to a defective powersupply unit !!!
Replacement is very expensive ;-(
Apr 19, 2009 | Sony PFM-500A2W 42 in. Television
Sony PFM-500A2W 42 in. Television Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
