Question about Linksys Computers & Internet
How can I make my desktop PC, which has Windows ME, wirelessly connected to the internet? Thanks!
Xcc
Posted on Apr 21, 2009
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
Dec 19, 2012 | Computers & Internet
I have a dell desktop with wireless connection, there is also a wireless router connected to the dell to send a wireless connection to a laptop in the household. in a bedroom in the house is a compaq...
As you mentioned, your Compaq Presario MV520 is using Windows 98 OS. As we all know, dial-up connection is the only available internet connection at that time so obviously Win 98 has dial-up LAN connection. However, you wanted to have wireless connection on that PC so you need to install a wireless adapter to that PC. First of all, most wireless adapters that are being used for desktop PC are wireless USB adapter, so you need to have a USB port on that PC. And also, you will need to check if the software for the wireless adapter will be accepted by the PC because since the PC is using Win 98 OS, we are not sure if the firmware of the wireless adapter will be compatible to the PC. Basically, my answer would be not possible.
Sep 14, 2011 | Computers & Internet
Making my desktop pc wireless
There is no built-in wireless LAN support in Windows Me, Windows 98, or Windows NT 4.0. Wireless network adapter manufacturers must supply all wireless and authentication functionality for these versions of Windows.
To configure a wireless client computer running Windows Me, Windows 98, or Windows NT 4.0, you must use the wireless configuration tool provided by your wireless network adapter manufacturer. Please see the instructions for the wireless configuration tool to configure 802.11 and 802.1X authentication settings.
Apr 19, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Setting up a computer as a wireless internet router
for windows xp you man set up the connection via cable or bluetooth and ms active sync - the htc (windows mobile) is able to use the hosts network connection.
you may also set up an ad-hoc wlan on you eee and turn on internet connection sharing for your mobile broadband connection. if you connect your eee to the ad-hoc wlan it should be able to access the internet
Mar 20, 2009 | ASUS Eee Box EBXB202-BLK-E0002 Intel Atom...
Reinstall windows xp to laptop now cant connect to the internet
Hi there.
You may have to use a keyboard toggle command, hold down Fn and if you can see a wireless icon on one of the F keys press it.
Hopefully the wireless will activate and connect.
If you can't see the keys post back with the make and model of the laptop.
Good luck and thanks for using Fixya!!
Feb 18, 2009 | E-Machines eMachines Desktop PC
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
My wireless G is properly installed but cannot find the internet
I have this problem before. I think I rebooted my pc but first make sure you have the firewalls turned off from windows and your security suite.
Nov 19, 2008 | Computers & Internet
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
