Question about Bosch 24 in. SGS09L02 Logixx Built-in Dishwasher
Bosch SGS09A02 Logixx no Hot Water and not completing Cycle.
When running a cycle near the end the display says 1 min left to go, after a few minutes or so the display moves to more minutes(30 minutes for example). It then changes from 1 min left and some other random figure continuously. This continues and the cycle never ends. I eventually have to open the door where the spray arms seem to be working but I can see the floor full of foam. The water seems cold, I have not felt the water hot over the last few attempts opening the door at the begin middle and end of cycles. After ending the cycle and closing the door the display says draining but even though some water is expelled a lot id left in the dishwasher after the displays says END.
  • 4 Answers
SOURCE: bosch dishwasher sgs43a52gb
it's pretty flaky and I didn't work when I tried to download a manual for my SRS43A02GB/08, but the parts-lists do.
If you go to the 'Launch the spare parts eShop' and enter your model number (you only quote it partially above, so you then need to select the particular model), you can see the exploded parts diagram - click right-hand icon 'print all pages' to get a pdf of all the exploded diagrams. You can order from here too and they seem a lot cheaper than alternatives, but I haven't actually bought anything yet.
Posted on Jul 13, 2008
  • 11 Answers
SOURCE: Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Posted on Feb 05, 2009
  • 254 Answers
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Posted on Mar 09, 2009
  • 412 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Mar 20, 2009
  • 27 Answers
SOURCE: Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
Posted on May 30, 2009
Dishwasher wont completely drain and turns off
Good Morning Friend,
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
May 14, 2014 | Frigidaire Dishwashers
Bosch SGS6302 Dishwasher failing to complete cycle
Does it heat properly? Was that the cause of the power failure?
Mar 17, 2014 | Bosch Dishwashers
I have a Hotoint Ultmia WMD947 washing machine. The countdown timer shows 1 minute left of cycle, but somtimes the cycle continues indefinately unless we restart with another programme, and even then it's...
It's probably due to the heating needing replacing. It may be covered in limescale if you're in a hard water area. My Bosch Logixx would stay at the 1 minute mark for a couple of hours, continually washing. If the wash cycle is not hot (you can feel the glass door to check) then it is very likely the failed heating element. You can order a spare for around 50 pounds (make sure you get exactly the right one for the model), and fit it yourself in around 30 minutes if you find the right online tutorial on YouTube. Replacing the heating element fixed my machine.
Aug 28, 2013 | Hotpoint Washing Machines
How do I stop my Bosch logixx 8 from beeping endlessly at the end of a cycle?
hi, I found out last night after being wokenup by endless beeping.... start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now....
May 09, 2012 | Washing Machines
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
My Bosch logixx dishwasher is sticking on 1 minute at end of cycle; the dishes will be clean but still wet rather than dry.
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Mar 03, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Hi How do you remove the child lock on a Bosch Front loading washing machine Logixx 8
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting
Nov 13, 2009 | Bosch Washing Machines
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch 24 in. SGS09L02 Logixx Built-in Dishwasher Logo
109 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
