Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Connectio it's not connecting to my t-mobile phone no matter what I do. It kept on saying can't find the device
  • Anonymous Apr 01, 2008
    My bluetooth worked when first set up. Now it says "unabel to connect".
    Sergeant:
    Champion:
  • 293 Answers
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps
Posted on Sep 19, 2007
How do I transfer my progress to my new device?
What kind of your new device?iPhone or Android phone.No Matter,many Phone transfer tool could help you,like MobiKin Transfer for Mobile & MobiKin Assistant for Android.Just need down the program,connect both mobile phones to computer,Choose Phone to Phone Transfer mode,transfer files from old phone to new one.
Complete procedure can be found on below link:
Phone Data Migration Transfer Data from Old Phone to Samsung S9
Follow the video guide here:
https://www.youtube.com/watch?v=PB2doh9YRTg
May 01, 2018 | Cell Phones
How can i fix my mobile data connectio?
your mobile data will not work because you might be still using the same APN from whereever you are. you need to go to you connections/data settings and use/select globe telecom for your data or you can send GPRS ON to 3333 to activate the gprs of your sim
Jun 04, 2014 | LG Vu CU920 Cellular Phone
How to connect f480 sumsung phone with pc using usb cable which comes with phone.pls step by step.
SAME PROBLEM To me>>>cannot connect to SAMSUNG NEW PC STUDIO By USB Cable which comes along with SGH-F480 .BLUETOOTH CONNECTION OK...BUT,...cannot upgrade the FIRMWARE!!!!!!!!!!!!!That option UPGRADE THE FIRMWARE On the right bottom corner cannot READ the PHONE...wHILE..phone already connected and TRANSFERRING DATA BY BLUTOOTH CONNECTION...HAVING PROBLEM WITH >>SERIAL PORT Connectio. help nme about this matter
Jan 21, 2011 | Samsung SGHF480 Cell Phone
My nokia n70 bluetooth is not working its says "unable to perform bluetooth operations".
hello,it could be as a result of two things,
1.you are not setting your bluetooth device properly,visit the settings part of your phone then you go to bluetooth settings to make sure it is put on and also has its visibility to other dvice kept on so as for it to function as supposed,if not done properly it will not connect with other devices
2.a corrupted bluetooth device,if this happens you will have to flash the phone with the use of internet and cables and this could only be done by an authorized mobile phone repair man.if he does the flashing i guess the phone can work but it's on a 50-50 basis.
wish you good luck,
take care.
Aug 15, 2010 | Nokia Cell Phones
I have a samsung corby gtb3410.When i connect my
when u connect ur phn with data cable u hav to choose mass storage option to use ur phone memory n card memory on PC it appears when ur touch pad is unlocked and u connect it to pc
Apr 21, 2010 | Samsung Cell Phones
My phone is very slow and freezing alot. also two messages pop up one says "memory full" two says "system error"even though I have upgraded the software and formated the phone like 5 times, making sure...
memory full-it is caused because the phone uses some internal memeory for ram like bluethooth connectio,wifi so please reset your phone to factory settings
system error-this is due to the firmware plz upgrade it to the latest version by connection to the pcsuit and plz do have an antivirus in your mobile
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
Sep 30, 2009 | Nokia N97 Cell Phone
My bluetooth range has some problem,it doesnt conects from a far distance it should be kept closely 2 other device
Friend your bluetooth device is faulty. You can replace it with the new one. Ask mobile technicians help for this matter to avoid further damage. good luck friend
Apr 18, 2009 | Sony Ericsson W700i Cellular Phone
Formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Dec 31, 2008 | Electronics - Others
Blue tooth
providing the mobiles that your trying to connect to are, bluetooth capable devices themselves. it,s the matter of getting the 2 devices to find or recognise each other ( connection Manager ) or device enabled settings.
If your mobile phone is Infa red then the 2 are incompatable. This can sometimes be determined via a little blue flashing light ( hence Bluetooth )
refer to your PDAs user and instruction guide for further assistance.
Mike @ compurepair.
Jan 08, 2008 | Acer N300 Pocket PC
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
79 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
