Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
PC not reading harddrive
Since installation the eternal harddrive was working fine. Now... a month later... for reasons unknown, the computer doesnt even pick it up. I have unplugged and plugged the usb cord and power cord and still the pc wont recognise it... power comes on on the external hard drive. I have plugged other usb items into same ports and the pC picks up and recognises them...but not my external harddrive.
any ideas...
  • roqmepek Apr 28, 2009
    after many mths of using, anywhere i plug, it just didnt detect my harddisk. i been plugging it on e same com after mths bt then it just stopped detecting.
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
Cannot get wifi using Anatel 802.11 a/b/g mini pci card to see any access points. Reloaded Xp; all drivers installed (no unknown device drivers); FN+F5 key does nothing; replaced wifi card - same symptoms;...
2 things, did your Wi-Fi pci-card come with laptop or did you bought it later, if its the later it could be a authorizing issue, or else it could be the router misconfigured for the computer like the new routers with WPA2 protocols doesnt "seeing" the old b or g cards in laptops
Mar 05, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
Reason 4 launch problem!! please help!!
If it worked fine in Win XP you could run the program in compatibility mode. Right-click on the icon and go to properties. Then click on compatibility. Then in the drop down box click Windows XP (Service Pack 2)
Jul 06, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Computer
First check all connection.Then format the operating system and reinstall it.
Apr 10, 2008 | Computers & Internet
Can't get projector and computer to connect! no image
CHECK THE VGA PORT OF THE VGA SPLITTER IT WILL BE OK IF U CONNECT A MONITER FROM THE OUTPUT END AND SEE IF THE PORT IS OK THEN LATER U CAN GO FOR CHECKING PC AND CABLES.
Apr 08, 2008 | Office Equipment & Supplies
SEAGATE FREEAGENT DESKTOP 500GB READS AS UNKNOWN DEVICE
Try this metho for xp,
rightclick ''my computer">>propties>>hardware TAB>>device manager>>You will see a list>>at the top off the list (without other option above) you will see computer icon with your PC name>> rightclick that>>scan for devices (the hard drive should pluged ) >> go on >>.need more help?
Mar 06, 2008 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
553 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
