Question about NetGear RangeMax WPN824 Router
I have a NETGEAR Rangemax wireless router. Everything appears correct (power on, wireless blinking, internet connected). However, when I try to connect with a wireless laptop, they can "see" the network but cannot get a response. The windows troubleshooting tells me the wireless router is not responding to the laptop's signal. I've checked the Netgear settings (via the Netgear website) and they all seem correct too. What could be causing the problem?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Do Firmware Upgrade
1. Please verify the model and version of the router underneath it.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and select the model of the router.
3. Please click on the appropriate version of the router.
4. Select the link of the latest firmware. Please click on the button Right-click and Save to Download.
5. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
6. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
7. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
8. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
9. Click on Maintenance and then Router Upgrade.
10. Click Browse and locate the upgrade file in your Desktop. Click Upload.
11. Please wait for the router to reboot.
12. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
Configure the router;
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 19, 2009
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
How to reset rangemax wireless-n 150 router?
Reset means that you will restore it to factory defaults which will delete all of the configuration settings of the router and will leave you not connecting to internet and wireless as well, but if you really want to reset it, just simply press the black button at the bottom of the N-150 router, press and hold it for at least 15 seconds. Once the lights on the router starts blinking, that means that it is successfully restored to factory defaults.
Dec 25, 2011 | NetGear Computers & Internet
Connecting netgear rnagemax router to clearwire
Restart the modem and router and you should be connected.
Feb 05, 2018 | NetGear RangeMax WPN824 Router
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
Oct 30, 2010 | NetGear RangeMax WPN824 Router
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear WPN111 RangeMax Wireless USB Adapter won't stay connected
Please let me know about the model number of the wireless router and the operating system installed on the concerned computer.
Aug 04, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Sep 15, 2008 | NetGear RangeMax WPN824 Router
Lost all internet connections through NetGear Router
I'm thinking MAC accept/reject list, check to see if it's active or not.
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Router Logo
290 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
