Question about Garmin StreetPilot C330 GPS Receiver
Volume control gone/no voice
I've been using the 330 for 9 months with no problems. Suddenly, no voice is being emitted from the machine. When I check the volume control on the side, the dial is stiff. When I move the dial, nothing appears on the screen (there are not the usual bars or the sound that accompanies increasing or decreasing volume). Also, the touch screen seems to be off, as I push on 1 favorite and I am given the one beneath it. Any ideas?
  • robynbmwz3 Jan 03, 2009
    My volume control is stuck all the way on loud, and I have the same problem where no bars show up when I turn the volume dial.
    Problem Solver:
  • 3 Answers
Under the front place mark GARMIN take your fingernail and pry it that should do the trick
Posted on Sep 19, 2007
6ya staff
SOURCE:
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have 2 Sanyo 8080 transcribing machines giving trouble
Hello I recomend to send it to service sound like a Motor problem Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 29, 2009 | Sanyo TRC-8080 Desktop Cassette Voice...
Volume on navigation system
Hi, I think I have a the solution. Simply turn the volume control up! Sounds cheeky but I had the same problem, then realised that while the announcement woman is speaking you can adjust the volume as normal, either on the unit or the steering wheel controls. you can get her to repeat what hse's last said be pushing the button with an ear on it.
Hope this helps!
Nov 16, 2008 | 2007 Mercedes-Benz E-Class
My text to speech functionality where the GPS read street names is not working on my TOMTOM XL 330 S. I have it set to the computer voice and the volume up but I actually get no voice instructions at all....
When you go to change prefernces/change voice don't use a recorded voice instead use the arrow forward or back to get to computer voice. Then you can select "read aloud street names"
Jul 18, 2008 | GPS
Voice prompts
Most likely there is a cold solder connection at the contacts of the volume control, or there is a break on the circuit board and you are pushing pressure to join the break, or there are other types of cold solder connections, or the volume control itself is defective.
Jerry G.
May 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Listening volume has suddenly become very low. I would like to raise the volume Thank you
Go to this website and download the manual. http://service.us.panasonic.com/operman/findmanual.aspx?model=KXTG6021
This model has voice enhance feature. There is a volume control on the answering machine and the handset. This manual will show you how to adjust both.
Dec 04, 2007 | Panasonic GigaRange KX-TG2432 Cordless...
Garmin StreetPilot C330 GPS Receiver Logo
115 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
