Question about Microsoft Office Word 2007 Full Version Corporate License for PC (059-05468)
Word template never changes!
Whenever I quite Word 2007, and restart it, the template NEVER changes to reflect any customizations I have done. I have tried changing the margins and paper size, then saved it as a template Normal.dotm in C;\users\bill\AppData\Roaming\Microsoft\Templates - and even then when I restart, I get the original template that came when Word was originally installed. It's driving me nuts.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 205 Answers
Tried to delete Normal.dot
you need to search for this file and delte it make sure you enable show hidden files and folders when you search this file
Let me know if it works
don forget to vote me
Posted on Apr 23, 2009
The PS Button on my PSP doesn't work anymore.
You have to open your PSP and replace the bottom buttons strip, probably it's only a damaged button.
If you have warranty take it to the store.
Jan 24, 2013 | Video Game Consoles & Games
When I open Word 2007 to write a letter, or anything taking more than one line, each additional line is in double spacing. How do I change to single spacing as it did in Word 2003?
Your normal template has probably been edited to double spaced text.
To fix this you need to edit your normal template file - it will live inside C:Program Files/Microsoft Office/ Templates or a folder under this or something similar to this.
Open your template and change the line spacing to single, then save it over the existing template.
Feb 23, 2011 | Microsoft Office Word 2007 Home and...
How do I change line spacing from double to single spacing? Whenever I commence to write a letter the second line is at double spacing as are all succeeding lines. How do I get it to single spaced lines?
Open a NEW, CLEAN document. Alter all the paragraph setting until you get them exactly as you want them.
Now the tricky part.
Save the document as a TEMPLATE and save to a folder you are familiar with. Give it a good name and below that on the dialog box, choose TEMPLATE (file type dotx)
Next time you need to type a letter with single spacing, open that template. When you go to save it, Word will prompt you for a file name as a docx, thus preserving your template for another day.
Feb 22, 2011 | Microsoft Office Word 2007 Home and...
Word 2007 saves and closes normal.dotm everytime I close it. It doesn't ask for anything, but it shows as an opened document in Word and start menus list.
It could mean that the normal.dot file is corrupt.
Try this:
1. Do a search for normal.dot
2. when found, change the name to "normal.dot.old"
3. restart your machine
Good Luck !!!!!!
Jul 21, 2009 | Microsoft Office Professional 2007 Full...
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Jan 30, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Office XP Pro
The "Normal" template opens whenever you start Word, and it includes the default settings for your new documents... as well as any customizations you may have opted for along the way. Sounds like your version of the normal template now includes the text of this document.
On the File menu, click Open, and then navigate to C:\Documents and Settings\user name\Application Data\Microsoft\Templates and look for "Normal.dot". You may need to change the Files of Type drop box to "Document Templates" to see it.
Open the file, select all the text you see there and delete it. Save the file and close it. You should get clean pages now when you open a new document.
Alternatively, you can use Windows Explorer to navigate to that same directory and delete the entire Normal.dot file. MS Office will simply create a fresh one when you launch Word again.
Hope that helps!
Good luck.
Sep 09, 2008 | Microsoft Office XP Professional OEM w/...
Problem with opening templates in Word 2007
I think you need a service pack with some old libraries supported.. This is quite common when upgrading to higher levels of VB.. eg 3 to 5 or 6 etc. If you have the un-compiled code, it can be fixed.. Or load an early version of VB will also fix it. If you have the code, send it to me. Let me know how it goes.. Rgds,
May 12, 2008 | Microsoft Office Professional 2007 Full...
Using drop-down form field in a word 2007 template
You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
Oct 16, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Word 2007 Full Version Corporate License for PC (059-05468) Logo
133 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
