Question about Toshiba W603 VCR
Toshiba VCR auto clock does not work, not way to set it. Please answer right away
No way to access Menu to set timed programs, clock will not auto set.
  • 2 more comments
  • Johnney Sep 19, 2007
    I don't want a bunch of tectnical explanations, I want to know how to set the clock, how to program my VCR to set the timer to record programs daily and weekly. Please. The manuel is lost.
  • Anonymous Mar 14, 2008
    I have a Toshiba W-614 R VCR,and cannot set the clock ! Please help. Thank you.
  • Anonymous Aug 20, 2008
    i have the same problem
  • ace_joker Aug 20, 2008
    i have the exact same problem
  • 21 Answers
You know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Posted on Mar 04, 2009
  • james42519 May 22, 2009
    forgot link her eit is
    http://www.tacp.toshiba.com/customersupp...
SOURCE:
Have a Toshiba TV/VCR combination, auto clock set. Also says MV13MS. The video casette is stuck inside. will not eject. How to open and retrieve is my problem. do you have instruction?
Opening any unit is dangerous as there is nice Voltage that will not go your way. But on this model you need to pop off the back and access the bottom over witch is a flipped situation. There is not really any step by step if you got a screw driver its basically your friend here, You need to open the back cover and remove it to access the rest the VCR is on the bottom of the unit and that is what needs to be accessed. When in doubt here seek a local tech because anything that has to to with online will be limited on Do SEE Do's But my first recommendation is to stay away from any deflection boards and the flyback transformer. Lets get the back off first and let me know if you have any additional questions after that.
please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Toshiba MV13L2 13 in. TV/VCR Combo
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Error message E 454039000 or E 454030206 or E454043002
I am not 100% sure on this one but it could be a problem with the clock if that DVD has a time display. Most of them try to get the actual time from the cable companies signal. Go to 'menu' and adjust/set the time manually. Disable auto time. Hope that works for you!
Dec 08, 2009 | Toshiba D-VR3 DVD Recorder/VCR
I HAVE A PANASONIC VCR ITR WORKS FINE, BUT THE
If you go into the menu you should see clock setting,there will be manual or auto,set to auto and the clock will set its self,even if the vcr is turned off.
Oct 09, 2009 | Panasonic DMR-E75V DVD Player/VCR
Change the time on DV 1130
Manual Clock Set
1 Press MENU to display the MAIN menu.
2 Use up/down arrors to choose the CLOCK menu.
Press ENTER and the CLOCK menu will appear.
3 Use left/right arrors to choose the MONTH option.
4 Use down arrow to choose the DAY option.
Use
L/R arrors to choose the date.
The day of the week will display automatically.
5 Use down arror to choose the YEAR option.
Use
L/R arrow to choose the year.
6 Use down arror to choose the TIME option.
Use L/R arrow
to choose the time.
Press and hold L or R arrow
to advance the clock
continuously.
7 Use down arrow to choose the DAYLIGHT SAVINGS
option.
Use L
or R arrow to choose AUTO, ON, or OFF.
If you choose AUTO, the VCR sets the clock using the
DST information broadcast in the signal (channel).
If you choose ON, the VCR adjusts the clock for Daylight
Saving Time automatically.
Mar 23, 2009 | GoVideo DV1130 DVD Player/VCR
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Jan 23, 2009 | Toshiba MV13M2 13 in. TV/VCR Combo
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Cant set clock or access menu using universal remote
Haven't found answer to that, but there is a remote contol specifically for your unit now on EBAY at http://cgi.ebay.com/SHARP-VCR-RRMCGO173AJSA-Remote-Control_W0QQitemZ350117240995QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116. The whole thing is under $10 including shipping. If nothing else, copy the model # of the remote and you might be able to find it cheaper someplace else.
Dec 04, 2008 | Sharp VC-H973U VHS VCR
Setting the clock/time
There should be a menu button on the remote which will get you into the various advanced programming functions. Many/most of the late VCRs cannot be programmed, time set with the buttons on the VCR itself.
Mar 12, 2008 | Televison & Video
Toshiba W603 VCR Logo
846 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
