Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the correct foot for embroidery. It is threaded correctly also. It seems to be a design flaw with the foot. When the foot presses down on the fabric the hinge forces it to go upward diagonally. Then when the needle goes down it hits the back of the foot and snaps. Please help!!! My machine is a Singer Futura CE-250
    Problem Solver:
  • 5 Answers
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
Posted on Oct 20, 2009
  • 128 Answers
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Posted on Apr 20, 2009
Needle breaking while embroidering
Could be tension is too tight. But there are also several other possibilities, ie something is not in alignment, so the needle is hitting the presser foot, needle plate, the needle is deflecting off the fabric. You might also try a different needle brand or type (ie, embroidery, top stitch, etc.)
Nov 13, 2016 | Sewing Machines
Needles break when embroidery carraige moves to sew new area
Check your needle for burrs or bends. If your needle is bent it will hit the plate. Try changing the needle
Mar 19, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
Having problems with metallic thread breaking constantly. I have adjusted tension up and down. I am using the net over the thread as directed in them manual. The bobbin thread continues to show on
I'm not exactly familiar with your machine but... a few things you should know. 1. You need a metallic thread Needle. or at least one with a larger hole. 2. Check your bobbin carrier, if anything catches or jams between between the spring and the case it can loosen the bobbin tension and make the top show too much bobbin color. 3. If your bobbin spring becomes grooved from the wear of the thread... same thing. 4. If your spring and everything is ok and clean... tighten the tiny screws to tighten the bobbin tension some.
Dec 23, 2012 | Sewing Machines
When I start to try to embroider the red light just blinks and I can not send tothe machine
you might try youtube for video's on embroidery
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 02, 2012 | Sewing Machines
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Upper needle thread breaks while embroidering, how can I stop it from doing so?
check to see if the needle is slightly rotated somehow when it was inserted intot he holder, if that appears ok I suggest just changing the needle completely,
Feb 17, 2009 | Sewing Machines
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Mar 23, 2008 | Husqvarna Viking 1
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
620 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
