Unable to install Operating system
I have GA81845gvm-rz motherboard with p4 processor with 768 MB (256 and 512) of RAM. my problem is that when ever I try to install Windows XP , the system goes well till the setup fills are getting installed and as soon as the screen appears ''Setup is Starting WINDOWS'' my System shuts down automaticaly. Some body told me that may be The RAM or SMPA causing the problem But I changed the both but still the problem is going on. Pls Help me with this Problem.
  • amos9salve Apr 21, 2009
    Ya Chris Thanks a lot for your reply. I did the same and the problem has been solved. Thanks once again for helping me and solving the problem. God bless....
  • lilchris173 May 11, 2010
    CPU could be overheating. During the setup the CPU is going a mile a minute. I suggest dusting the PC with compressed air.... outside... I'm not calling this a solution, but i think it could be the problem. If cleaning the thing out works, you should probably replace the CPU fan soon. You can buy new ones from www.newegg.com thats where i shop..
Display Problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with 2.4 GHz Intel Pentium 4 Processor and 768 MB RAM and 80 GB HDD . When I start the computer nothing appears on...
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
Jul 08, 2011 | Intel D845GVSR Motherboard
Can 1gb ram supports tally software with atom processor
System Requirements
  • Recommended Hardware Requirements for Tally 9
  • Pentium 4 and above or equivalent
  • 256 MB RAM
  • Minimum Disk Space: 40 MB
  • Operating System Software: Microsoft Windows 98/ME/NT/2000/XP
Hence, your system would definately support Tally.
Hope it helps! Good Luck!
CreativeTECH
Mar 19, 2011 | Samsung Netbook / Intel Atom Processor /...
I have a p4i45g MB with a p4 Processor. Do i use
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR 266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
use DDR1
Jul 14, 2009 | Computers & Internet
How i down load our p4 sound and video drivers
use Original CD driver for your MOBO or you can download it from they homepage
May 10, 2009 | Intel Motherboard
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
I NEED RAM
Hi zouganeli,
You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
Hope that helps
Take care,
Michael
Nov 14, 2008 | Computers & Internet
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Installing P4 2.8ghz cpu
That particular motherboard only supports AMD processors:
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1764
You will need a new motherboard to use your Intel 2.8ghz chip.
May 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
COREL x4 running very slow & spooler problem
System Requirements:
Processor:
# Pentium III, 800MHz or AMD Athlon XP
Operating System:
# Windows XP with Service Pack 2 or later
# Windows Vista (32-bit or 64-bit editions)
Hard Disk:
# 430 MB
Memory:
# 512 MB RAM
Optical Drive:
# DVD-ROM
Other:
# 1,024 × 768 or better monitor resolution
# Mouse or tablet
Where these are the minimum specs I would recommend at least 1+gb memory and a good graphics card and a P4 or AMD processor running at 1.8ghz or better, and that would depend on how in depth you get into the program
Mar 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
