Question about Sony FD Trinitron WEGA KV-32FS16 32" TV
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not turn on at all. Set is too heavy to take to a repairman. Any ideas on what the problem is?
  • 4 more comments
  • rgiaccio Dec 24, 2007
    I have the same problem. I am not familiar with the internal components mentioned in the solution. How can I identify and if necessary replace them?
  • candinga Dec 25, 2007
    cannot turn it on either the remote or set up switch. There is a click and red light blinks but no sound or picture. Tv is too heavy to take it to repairman, any idea on what the problem is?
  • gilroymama Jan 10, 2008
    I am having the same exact problem. It eventually turns on, but from what I gather there is no simple fix, so I going to use it until it stops working all together. My concern is, is it safe to keep using it until it stop working or is there a fire hazard associated with the issue?
  • Anonymous Feb 23, 2008
    Yes, the same problem, I cannot turn it on.
  • whiteoak2552 Apr 06, 2008
    When I turned it on tonight, it made a loud pop and would not come on. The standby light flashes 4 times and pauses, then 4 more times. When I press the power button again, it makes a sound as though it's turning on, but I get the same flashing standby light.
    Like everyone else, this heap is too heavy to move. BTW, what is a "pulse wire and anode cap" and "flyback transformer?" This sounds like repairman speak which means I have to find five people to help load it on the truck for a trip to the repairman. Last Sony product I'll ever own...
  • Anonymous Jul 23, 2008
    Count me in too. I just moved to my friends house and he has
    one. Switch it on and it just clicks and a light pulses but
    doesn't turn it on. I have a Sharp Aquos that I can replace it
    with but was going to keep that in another room. It is way too
    big too haul anywhere.
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not turn on at all. Set is too heavy to take to a repairman. Any ideas on what to do
Posted on Dec 07, 2008
Check the pulse wire and anode cap if it is connected tightly, then if ok the false is the flyback transformer
Posted on Sep 19, 2007
Sony Bravia model kdl46ex620 red standby light comes on when you turn on by remote green light comes on then clicks off to red blinking led, 6 blinks then repeats.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 11, 2016 | Sony Televison & Video
Sharp 29 inch crt tv on timer flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 01, 2015 | Sharp Televison & Video
Green light blinks 7 times on flat screen before turning red. there is a picture for 5 seconds
Good morning
Take the remote and find set up and picture. Try to adjust the brightness and see if you do not get rid of the green light.
all the best
kolbrun
Jul 08, 2012 | Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not...
the initial symptom is usually caused by microprocessor as it is not initializing correctly. followed by 4 blink error which is i2c communication failure also specific to microprocessor would recommend replacing small signal board as microprocessor is located on that board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-32FS16 32" TV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
