Bose Acoustimass 5 III System
Problem for Bose Acoustimass 5 III System
Base too heavy for downstairs neighbors
By Fixya673 on Apr 19, 2009
Hi, I have the Bose Acoustimass 5 speaker system. Recently it has come to my attention that my neighbors in the flat below are always hearing the bass from the bass module. The module is place on the floor in the corner of the roof with one side against a couch, the other a foot away from a build in cupboard and the back of the unit against the wall. I have pulled the module away from the wall but was wondering it perhaps it should be in an upright position or if one can put foam / rubber or some sound absorbing material under the module so that the bass is softer on the floor? Would really appreciate your views. Many thanks.
Best Solution
posted on Apr 19, 2009
Very Helpful)
CABLE CUY
Rank: Wiz
Rating: 85%, 73 votes
Try a board with two screws through the front and one at the rear,set on the floor points down and then set your sub on top,this should help,also if you make 2or3 boards your bass should be tighter and not travel so much down to the flat below but will not go away,sorry but the only other thing you can do is buy ear plugs for your neighbours.
Hope this helps.
CABLE GUY.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
dynami
Rank: Wiz
Rating: 90%, 21 votes
If the sub is not too heavy you can buy wall mount speaker brackets and mount the sub up by/on the ceiling in that corner. Just think of it as a mirror image of how it looks on the floor. When mounted this way you will still be taking advantage of the rooms acoustics, just like before, except your (downstairs) neighbors should be happier. The only problem is if your home is poorly insulated it could still "leak" down their walls. So it would help to use an outside wall as one or two of the walls that make your corner. Another option would be to move the sub to the middle of the room thus negating the positive effects you get from the sub being in the corner. It should, however, be a little less boomy and shouldn't travel as far.
-Dynami
Was this helpful?
Yes
No
Popular Solutions for Bose Acoustimass 5 III System
Questions and Unsolved Problems for Bose Acoustimass 5 III System
Do you recommend Bose Acoustimass 5 III System?
Answer
Answer
All the wires seemed to be connected but not getting any base. Have tried changing settings on amp,... (More)
Answer
how many watts needed to have good quality of sound to my am5
Answer
how do i powermy bose free space3 acoustimass module set? please help me understand the powering... (More)
Answer
how do I hook up my bose acoustimass 5 speakers to an amplifier and Plasma tv
Answer
I need a wiring diagram for Bose Acoustimass (sp?) 7 speakers. I will, of course, have a reciever/... (More)
Describe your Home Theater Speakers and... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
in , MD
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
