Question about Sony KP-48S65 48" Rear Projection Television
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
I wish to fine tune the convergence cause in the center of the screen it's good but sides and corners are blurry.
  • tobeornot Oct 14, 2007
    I think it's real close to what I'm looking for but not exactly, maybe it's not the same model. Mine is the kp48s65 and buy in 2000 and when I enter service mode and cycle trough the menu I dont see any PJE FDIS. I don't want to damage anything so I made more research about it before changing anything. I find this link:
    http://www.keohi.com/keohiHDTV/experttip...
    But its not working too cause mine is not a HD and I can't find the CXA2150P-1 menu. Also the warning at the top of that page push me to ask more questions:
    Warning: multiple hours of convergence work will lead to crt burn in
    Did it mean I have to make those change really fast and cant take time to fine tune it? Right now, on a 7yr old 48"  with convergence  corrected in the center I see a difference  from 1/8" to 1/4"  between red and blue at each corners. Did I'm looking for something my old tv set can't give anymore? Cause except during nascar races where I got troubles to read drivers stats, I like that screen and don't want to change it for now.
    Thanks for your help.
  • Qster Dec 30, 2007
    I have the same problem.
    I tried to adjust the Convergence setting in the SETUP menu but it doesn't help, the lines matches in the center but off on the sides. The center of the the screen looks good but all around the edges are blurry with multiple colored lines visible.
    I tried to follow the instructions but couldn't get to the service mode. Any suggestion or advice is greatly appreciated.
  • 105 Answers
You will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
Posted on Oct 13, 2007
SOURCE:
Model kp-53xbr4ct made 1998. picture was good. sudden went to center of screen and bowed up and down from center. it hade sound. turned of, now no sound. stand by flashes 6 times. unplugged , plugged back...
the video color distortion with the bowing in the center is called a convergence failure. the 6 blinks indicate a power supply shutdown for high voltage protect. the 14 blinks is just the tv trying to turn back on. you may be having to problems with the convergence and the 6 blinks or it may be related because the convergence amps can cause shutdown if they are shorted. i suggest calling a serviceman per the possible tow different failures. good luck
Jan 12, 2011 | Sony KP-51HW40 51" Rear Projection...
Sony kp-ws500 has very fine red and blue horizontal lines across screen tried adjusting convergence, and it didn't do anything
Red and Blue Tube screen drive controls needs to be turned down some, tubes are over driving causeing drive lines.
Sep 16, 2010 | Sony KP-65WS500 65" Rear Projection...
I have a sony 50in rear projaction model kp-48v90 and when its on the right and left sides have a slight red streak on the sides but not in the center what can i do to fix this problem at home
U can tries go in ur convergence menu.Tries auto or manual lines up the +'s together.Not able to,ur convergence are dead.The shop will cost u $300-350 to fix convergence problems for parts and labors.
Apr 02, 2010 | Sony KP-53V90 53" Rear Projection...
Tried to use 2002 Sony TV as large monitor for webinar. Got the TV to accept signal but could never size the screen correctly. It only showed part of the computer image. Gave up on using it as large...
Symptom shows that it is convergence out chips failure that causing misaligned images on screen. Please replace convergence out chips in tv to get converge picture.
Question shows it is Sony KP-46WT500, if it is different model let me know please.
I can provide you more technical assistance if you wish to repair tv by yourself.
Thanks.
Feb 09, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a Sony KP-51WS510 and the convergence is
Dear Doctor,
Check pico fuses PS8001 to PS8006 on D board where you replaced both STKs.
Make sure +22 volt and -22 volts are being supplied from power supply (G board) to D board.
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Problem with my colors on Sony KP-46wt510
Sounds like the convergence ICs are giving out its a fairly commom problem with all projection TVs. Your model uses two STK392-560 ICs but I would suggest getting a couple of the 4.7 ohm 1/2 watt convergence resistors as most times one or two of them are open as well.You can get new replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony kp-53s25
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
good luck
please mark the post with a fixya!
Nov 21, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
303 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
