Question about Canon Pixma iP6600D InkJet Photo Printer
Canon ink tank problems
I often get the following message on my Canon iP6600D ink Jet printer. "More than one ink tank of the following color is installed." It is always referring to the same tank the photo cyan. I have refilled them many times and the message continues the same. If I remove the ink tank and reinstall it will eventually work. Sometimes it takes several times before it works. This is very frustrating and time consuming. Is there any way to by pass these messages? Thank you in advance Grampa9
  • 19 more comments
  • norrell13 Dec 13, 2007
    Took The Tanks out and re inserted 4 or 5 times, Blew out with air.But it still comes up with the error U071; I have two ink tanks of black ink installed.
  • pisolo2 Jan 10, 2008
    I have the same problem with CYAN tank. After I re-install the tank 4/5 times I get the error U150. The tank is no more recognized. For this reason I have throw away two NEW tanks. UNGRY!!!
  • Anonymous Jan 20, 2008
    I have been having the same issue only with the magenta ink tank.  I too would pop the tank back in, but usually just lifting the cover and closing it again is enough to solve the issue though I sometimes have to do this several times in a row.
  • sdodson Jan 28, 2008
    I also experience this problem with both the Yellow and Photo Cyan cartridges. I would definitely recommend AGAINST purchasing this printer as the error U071 appears even on brand new ink cartridges. There needs to be a way to bypass this error condition!!!
  • NicHider Mar 03, 2008
    Hi there
    i have only just got round to replacing the ink in this printer. All inks aprt from the Cyan photo needed replacing but now I have the same problem - it wont recognise the cyan photo cartridge. Im on my tenth atempt now to get it to work but no luck so far - I thought Canon were suppost to be good !?
  • Anonymous Mar 06, 2008
    I have the same problem with this printer. Mine is with the magenta ink tank, where the message keeps coming up with 'More than one ink tank of the following color is installed' . I always buy cannon ink. I turn it on and off, on and off and eventually it works. Very frustrating when trying to get an important item printed.
  • postalquincy Mar 07, 2008
    Same problem but only the Magenta. I have replaced the cartridge more than once and still the problem exists. Canon Tech rep. acts as though there is no problem. When it works I like the print results. If you want to fix this problem the ONLY solution is to constantly open and close the cover until the error message goes away. Eventually I'll get a new printer. The nice thing is I don't have to look at Canon models anymore!
  • jennieg Mar 16, 2008
    See Jennieg's comment it is the the same.
  • Anonymous Mar 26, 2008
    Last month my 1 1/5 year old iP6600D printer started to tell me I had more than one magenta ink cart. installed. I replaced the cart with a new cart. The new one worked a few days and now it the printer says U150 unrecognizable cart. with the Magenta ink. What's up CANON? Your web site was no help.
  • Anonymous May 22, 2008
    Exactly the same problem with an error message reporting two ink cartridges of the same colour have been installed. Genuine cartridges being used and not refilled. Canon helpdesk eventually tell me (after several emails asking questions that they already have the answers to) to try (buy) a new cartridge as the problem might be with the cartridge -- at their prices they must be joking! Last time I buy a Canon printer.
  • Anonymous May 24, 2008
    How do I access the cartridges in the Canon PIXIMA iP6600D to replace an empty cartridge?
  • maple005 May 25, 2008
    yep, exactly the same problem, Only solution being to open and close the lid, reseat the ink tanks and eventually (though for no identifiable reason) it sorts itself out, until you turn it off and then next time back to square one again. Mine started doing this about 6 months after purchase. Guess what my next printer is NOT going to be...
  • gbabe689 Jul 18, 2008
    Same problem with black ink cartridge. It warns that more then one is installed. I have always used new ink cartridges. It started after one year.
  • erra70461 Aug 22, 2008
    I have the same problem more than one ink tank or the following color is installed. How do you fix this. The ink tank is full!
  • Kieu Oanh Nov 01, 2008
    Yep me too same ink tank message - that I have two of the same color. Now it worked ok for the 1st 6 months but now I can never count on it printing, in fact I have been fooling with it for two hours last night and two hours this morning. Reset the cartridge , turn the printer on and off, put in new cartridge . It doesn't matter what I try It won't work!!!!!! I guess Canon will give me the runaround or put a bandaid on by sending a new cartridge - and then it will happen again like to everyone else. I've had this problem already 3 mo. but eventually it would print blk. But heaven forbid now I need color prints. Never again will I buy a Canon Iif they won't make this right. Meanwhile,I work out of home and NEEEED some things printed. I guess I'll have to buy a new printer again!!!!!
  • angiejohnson Nov 03, 2008
    Same problem, Cyan. Is there a solution?
  • Bikerdels Nov 20, 2008
    Same problem! I have contacted Canon an I am awaiting their response in next couple of days. Will keep all posted!
  • pp2tom Nov 27, 2008
    my ip6600d went KAPOOT in august 2008, flashing the U150 error OVER AND OVER AGAIN. i've bought new ink and tried switching the chips, etc. nothing has worked. this machine is less than 2 years old. i've had no luck with canon support service. we thought this was a high quality photo printer. wish there was a solution. will try buying ANOTHER cyan ink tank and will return the faulty one, let's hope it works this time!
  • Anonymous Jan 01, 2009
    Have you solve the issue with U150 error? I have the same with U140 error which is the photo magenta ink tank
  • lejuron Jan 14, 2009
    After literally an hour and a half of "lifting the lid" and repeating I gave the 6600 a swift kick in the side and it worked! Who ever said violence never solved anything?
  • mikeanchris Apr 08, 2009
    I get error u150 and I tried everything I can think of I could get a new ink tank but I won't be happy if that doesn't work. Might be time for a new printer any ideas on a better one?
I think I figured this B!tch out.
When you get the error:
"More than one ink tank of the following color is installed" or
"Ink cartridge not recognized"
Open up the lid where the cartridges are and hold done the "SEARCH" button. This has been working for me, and I bought my ip6600d in 2005, so my machine is old, and ready for this..........ORIGINAL INK!!! Never really used it beyond printing very few pics. So I was really pissed when I found these messages to almost 5 years after buying this printer. So to recap, open the lid where the ink cartridges are while holding the "SEARCH" button, hold it up for like 5 to 10 seconds, place lid down still holding the search button, then let go of the search button. I did notice the alarm was lit, but went away after I released the search button. Good Luck!!!
Until I held the search button down I had turned of the printer, reseeded the cartridges and open and closed the lid but it never worked.
Posted on Aug 13, 2010
  • realvivid23 Aug 26, 2010
    Hey, this tip worked! Except for me it wasn't the "search" button but the "OK" button.
I have the same problem, purchasing a new and genuine ink tank was no help. Only removing and reinstalling the tank, sometimes multiple times, seems to correct the issue. Every time it is the Magenta tank too...
Posted on May 29, 2008
Totally pissed.  I have the same problem.  **** Canon.
Posted on Apr 13, 2008
Hllo
i will replacing an new ink tank to PIXMA 6600D CAN you helpe me plaes
Posted on Feb 25, 2008
I have the same problem, which is what led me to this forum. As you say the only solution I have found is to remove and re-seat the cyan cartridge.
Posted on Oct 04, 2007
This printer is crap!!! The cartridges are more expensive then the printer itself... and I still have this message...It usually worked with all your tips and tricks, but now it won't work at all...Can I bypass this message and print anyway? I want to print in black and white!!! I don't need this Magenta color!!!
Posted on Jan 26, 2008
My IP6600d has suddenly refused to print, saying 'the following ink tank cannot be recognised'. It says its the yllow cartridge, which is half used and a genuine canon item. I have tried taking it out and...
Have you checked the quality of the chip on the yellow ink tank? If scratched, the printer will not be able to read the ink tank information and will stop. I had to replace an ink tank in the past with another one with a new chip due to the first one was defective. If you have a spare yellow tank with chip, you may want to replace the old one so you can continue on.
Dec 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Error message more than one ink tank of the same color is install
You need to take all inks out and install 1 at a time to see what the display says after each. Sometimes you get a defective ink tank and it will report on the wrong one. Canon will replace a defective tank within 30 days of date of purchase.
Nov 04, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Alarm: UO71 more that none ink tank...
That means that you either have a defective ink tank, or there are two of the same color installed, check the label for the inks, the one that flashes is the one with a problem.
Oct 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
On my printer MP530 I get the following message: INK LOW M, I have refilled the tank M (color red) which was empty and the message continues.
refilling the tank does not solve this problem, canon design this printer to have their ink tank replaced, so do not worry too much about the ink level, as long as the printer prints you are fine....all you need to do is refill every time the print quality is not good, don't wait for the ink to dry up, this could cause damage to the print head.
Sep 25, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon IP5200 printer - "duplicate ink tanks"
Hi i have Ip 5200 but the pawer lamp and yelow lamp are blink
Mar 26, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
907 people viewed this question
old marine
old marine
