Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Yellow/green screen on a Panasonic PT-50LC14 - Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
  • marksawyer May 20, 2009
    I replaced the bulb in my pt 50lc14 and now it has a yellow tint .
spqr163
  • 37 Answers
SOURCE: tv will not power up Panasonic PT-50LC14
ok guy's i have the same tv and simular problems, first check the lamp light located next to the sd disk input (on the front). if it's not blinking then 2 things 1) more than likely it's the lamp if you haven't replaced it by now your one of the lucky ones, you can find them online for around $100, in which i paid over $300 for two differnt bulbs. the warrent only covers 1 bulb. 2) this happens to me once in a while try unplugging it let it set for a minute or two, replug it back in and try it again. but it depends if the light shines yellow (orange) and blinks twice, then try it again. you kinda have it cycle through and that should work. if not then unplug the unit, then take off the front cover and use a philips screwdriver remover the bulb (located behind the cover in the front) then i highly recomend doing this on a weekend pull out the shop vac and **** out the dust inside the lamp housing, then take off the back housing along with the left side speaker and first clean it out with a rag, then go through it with the shop vac. basically if dust builds up the unit will trap the heat and that it's why it will overheat and shut down.
Posted on Mar 12, 2009
  • 59 Answers
SOURCE: Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Posted on Oct 23, 2007
  • 3 Answers
SOURCE: grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Posted on Jun 04, 2008
SOURCE: Panasonic PT-50LC14 wont turn on
Ok well it's the shop for this bad boy I am afraid.. to me it says Power Supply OR fault that causes PSU to shut down.. either way unless ya a dab hand at this type of thing, its obtain a reputable serviceman and get a "Quote" and proceed from there.. GL
Posted on Jul 29, 2008
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tip
I hope that helps.
on Apr 30, 2010 | Televison & Video
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 wont turn on. the power button doesnt turn green when i push it, it stays red and the screen stays off.
Jul 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Grennish/yellow spots pt-50lc14
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
GREEN TINT
It is almost certain that the light engine is your problem.
Dec 14, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
451 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
