Question about Averatec 6100 Notebook
I can't wake my averatec 6100 laptop!
I have a averatec 6100 laptop, I can't wake it from sleep, I tried pressing the power button lightly, and pressing buttons and nothing but the flashing sleep light goes off! please help me. sincerely, summerrory.
  • lilchris173 May 11, 2010
    when you say lightly.. your computer isn't going to turn off if you push it a bit harder and hold for a solid second. If you hold it for a few more seconds it will force the computer to turn off. Give it a try.
How to wake up from sleep function?
just press power button .. if your power light is blinking
Mar 23, 2014 | Dell Precision M4400 Notebook
Pressed the sleep button..how do I get it to w"wake-up?"
Is there an actual button on your keyboard that is the sleep button? Or did you put it to sleep within Windows?
If you pressed the sleep button on your keyboard, you should be able to press that button again, and it should wake up. If you pressed it within Windows, then pressing any key should wake it up.
If neither of those works, then sometimes you need to press the power button. Don't hold it down, just press it, and your computer should wake up.
Hope this helps!
Thanks for using FixYa.
Aug 27, 2011 | HP Computers & Internet
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Not wake from sleep or hibenate
Usually, to wake from sleep pr hibernate, you just need to press the "Power" button of your laptop. It will not turn it off or restart the laptop if it is in the "sleep" or hibernate mode. Pressing any key usually wake it up. The default way is to press the power button as if turning it ON for the first time.
Feb 11, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
My mac laptop doesn't wake up from standby/sleep
Check out these possible solutions:
http://www.christopher-chan.com/blog/index.php?/archives/588-Macbook-Pro-wake-from-sleep-problem.html
Jul 10, 2009 | Apple MacBook Pro 17 Notebook
Svideo on a averatec 6100 series
Try pressing the Fn + F2 keys on the keyboard.
Please don't forget to rate this solution.
Jun 14, 2009 | Averatec 6100 Notebook
How do i wake it after i open it
lightly press the power button, or press some keys.??
Mar 04, 2009 | Averatec 6100 Notebook
Dead sleep
happened to us many times, the sleep to death error
logic board problem. buy a new mac realy.
try this, reset prom
take out the power cord. press hold the power button
and plug the power then takeoff power button and press it again.
try this, press hold P and I and power on
Feb 21, 2009 | Apple iBook G3 Mac Notebook
Where enable wi-fi acces on Averatec 6100 series?
right nest to the power button is the wifi antenna button insure that it is green indicating that it is turned on
Dec 20, 2008 | Averatec 6100 Notebook
Averatec 6100 laptop problem
Display Driver is troublesome.
Contact Service Point and they'll reinstall the Display Driver for you.
Sahaja Yoga is the Only Solution to all the Problems of World and is the Mahaa Yoga.
Apr 03, 2008 | Averatec 6100 Notebook
Averatec 6100 Notebook Logo
137 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
