The machine will wash but stops when it gets to spin mode.
    Scholar:
  • 126 Answers
Different brands opperate in two ways,one is the water must pump out to continue and other is lid switch on top load and door switch in front load if water pumps out then switch failure should be the cause but if no water exits then pump drain could be clogged or pump failure are the most common causes for these problems
Posted on Apr 19, 2009
The spin mode on my washing machine has stopped working
The is a spin clutch soliniod which gets water on it ,rusts it up over time until it becomes seized.Replace!
Jan 15, 2016 | Washing Machines
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Washer won't finish spin No error codes
check the pressure is not sticking in the high position if the pressure system is blocked the air might be slow getting out stopping the pressure switch from dropping to low level by the time you get to the machine it has had time to drop to low and will allow the machine to spin
Mar 11, 2014 | Indesit Washing Machines
Hitachi sf-95kj washing machine stop and shown error code c4 when it's go to spin mode
A lot of new machines need the hoses cleaned out. The slime up. The pump gets shut down and the unit won't spin. Unplug unit before you service it to avoid shock. Top has to come off, and front also.
Nov 16, 2013 | Washing Machines
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 12, 2010 | Washing Machines
Will not drain and spin....stops ..will only start wash and stop.
check the lid switch if is clicking if not try to by pass the switch
Jun 18, 2009 | Washing Machines
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
