Question about Plumbing
The hot water in my bath tub is suddenly running slow while the cold water runs fine.
  • jangstew Apr 20, 2009
    My hot water will not run at all, while the cold water runs great. Everything seems to be fine untill you try turning the hot water on.
    President:
  • 2,692 Answers
Turn off the hot water at the stop or tank remove stem assemply. Lok for obstruction. turn water on momentary with stem removesd to blow out restruction. Reinstall stem. If the problem stil exists. turn water off at tank and dosconnect at tank Backflush line from valve to tank by holdign hand ovr spout while turning cold water on. Have bucket ready  to catch water at tank. Reattach line.
Posted on Apr 25, 2009
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Bath tub faucet will only run hot. Just started
It sounds like the seals are going bad. Moen is probably rebuildable. You can go to a Menards and ask if they have the replacement guts for your particular model.
Nov 17, 2009 | Home
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
if the hot comes out when you first turn on you have hooked up hot and cold backwards
Feb 11, 2009 | Home
Plumbing Logo
248 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
