Question about Dell Dimension 8200 PC Desktop
Hard disk size read wrong by bios
Have a 60GB IBM Deskstar IC35L060AVER07-0 harddrive installed as Master on it's own in an 8200 motherboard CPU Pentium 1.80GHz according to both Dell's manual and that of IBM. The BIOS is reading back a capacity of just 33820 MB. Is it a limitation due to the age of the motherboard. Can the BIOS be flashed safely? Regards, Sweet Chilli
  • sweetchilli Sep 20, 2007
    Took your advice Paytonlink and flashed the bios to A09. However, I still had the same problem. I decided to try out another hard drive at 160GB. the BIOS read back 160GB so the fault was the IBM Deskstar. Dell diagnostics didn't like the drive either saying it had smartdrive problems.
    Thanks for your help Paytonlink
  • 44 Answers
You can easily flash the BIOS and see if that fixes the problem. Dell has a BIOS version A09 on their web site (http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=308&libid=1&releaseid=R49451&vercnt=7&formatcnt=0&SystemID=DIM_PNT_P4_8200&servicetag=&os=WW1&osl=en&catid=-1&impid=-1). You could try that. Just make sure to have your computer on a battery backup (UPS) while flashing the BIOS. If the power were to go out in the middle of flashing, you may cause damage to the BIOS chip.
Posted on Sep 19, 2007
SOURCE:
I have just tried, for the first time, using my new 320GB Canvio. The white pilot light comes on, and I feel the disk spinning for a short time, but there is no operating software presented, and no file...
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Mother board came with pc with 160 gb hard disk I have added 500 gb hard disk in addition thepc isworking well and it cannot recogognice the extra hard disk and I have to tighten the jumper connection of...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Dec 16, 2010 | Asrock P4I45GV R5 Motherboard
I have an IBM Thinkpad 1200 and its running slow, i need to change the CPU to a faster one. What CPU is available for it?
I think cpu changing is not wise in budgetry if really you need to make your device faster .
if really you want to make it faster just change the motherboard and cpu to gether but still its not resionable.
better to try and increese the ram and the use faster hard drive .
and run only the programs only required by disabling application on startup.
Dec 13, 2010 | IBM ThinkPad i1200 1161 Notebook
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
IBM Deskstar 120GXP 123.5GB
That model acer is a newer system; pentium dual-core; so bios limitations should not be an issue. With the 120GXP older drive; check that the 32GB jumper is right. The pins have a label (red text) on the back; ensure it is set to master (according to the far left label) not the right. It will take 2 jumpers; not just one. See how that works. Also, check your bios settings; and ensure the IDE power ... is enabled. (for example secondary) may be disabled. Or, check that "legacy" support is enabled in the bios. Please rank me if this helps. Please check me out on facebook http://facebook.com/techrx http://techrxgb.com
Feb 22, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
I have a 60GB ATA/133 HDD How do I set it up for an AMD K-7 motherboard (jumpers would be for master hard drive
WHAT hard disk brand?
is your HDD a slim type? or the strandard
for hitachi, ibm, exeltor brand
change your jumpers to........ LIMIT CAPACITY probably 40gb reading.....
Apr 25, 2008 | Computers & Internet
IBM Deskstar Model IC35L040AVVN0-0
Well, I guess your running windows XP ? If you open the disk manager, does it show up there ? When you reboot, does the Bios discover the drive ?
May 29, 2007 | IBM Deskstar 22GXP (DJNA-372200) Hard...
Dell Dimension 8200 PC Desktop Logo
116 people viewed this question
Ekse
Clive
Clive
