No sound on Windows Media center.
The sound works for media player, but not for tv: .National Geographic chanel
  • 69 Answers
Connect a two end steerio pin cable  tv tuner card`s audio output(green) to pc sound card`s input(blue)
Posted on Apr 19, 2009
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
No start up music when opening media centre
A. As you have stated that "music plays just fine" and you also said that "there is absolutely no sound", so I am a little confused on this issue. Could you clarify whether you get any sound while playing a song/video on Windows Media Center or is it an issue only with the navigation sounds on Windows media Center? B. You may check the Volume mixer settings for the Windows Media Center.
Cross check the settings.
Here is how:
1. Right click on the Speaker icon on the task bar.
2. Click on "Open Volume mixer".
3. In the Windows Media Center mixer drag the slider down till you get the adequate sound.
Mar 26, 2013 | Audio Players & Recorders
National geographic complete 109 years
Looking at system requirements (windows ME and lower), I would say this probably will not run under windows 7.
Mar 29, 2012 | Mindscape The National Geographic Complete...
How to use in built TV tuner in lenovo y560 laptop
In windows 7 - Windows Media Center will use it (NOT media PLAYER, media CENTER)
media center is actually wicked cool for watching TV because if you have cable, no more waiting for the listings channel...it pulls up to 2 weeks of listings from your provider, so you can schedule shows to be recorded, record series etc...very cool!
Mar 03, 2011 | IBM Computers & Internet
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
Nov 02, 2009 | Microsoft Windows XP Home Edition
Windows media center file issue
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Dec 25, 2008 | Microsoft Windows XP Media Center Edition...
Play dvd nothing - play s/d card (video) sound but no picture.
You need to update the dvd softwear. Check the default settings for playback of media,if it is set to windows media it won't work if you hav'nt installed the correct updates. Choose the Toshiba dvd player as the default player and it should work. If you prefer windows media then you can get the updated codecs from ' free-codecs.com ' Easier still,try uninstalling your windows media player and installing windows media 11, this will usually resolve the problem.
Oct 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Sound cuts out on one speaker
Are you able to get sound on the speakers without the media center? In case if the problem is just not limited to media center-Then it could be a sound driver issue...!
In case if the sound works fine outside the media center then its a setting problem with the media center.i suggest you run the first run wizard to reset the media center.
To reset the media center
1)Navigate to
C:\Documents and Settings\All Users\Application Data\Microsoft\eHome
locate the file- ehshell.config-Just right click and delete it
2) delete the following registry keys
open registry editor
Start > Run > type regedit and hit enter
it opens a registry editor window
locate the following keys
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings
right click on these keys and delete them..You just have to dig down to these keys and delete them in the left hand pane. and then close the registry editor and restart the system.
After the reboot windows will ask you to reconfigure the media center-you just have to follow the wizard to complete the process...This should do the trick and should avoid a complete reinstallation of windows.
Good Luck.
Nov 01, 2007 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
David Payne
David Payne
