Question about Sony CRX230E CD-RW Burner
Door i have just bought a sony cd writer that has come out of a machintosh and i have installed into mine diamond data all is ok however the door does not open. please rescue me. open for anything right now. thanx
    New Friend:
  • 8 Answers
Grail Montes explanation above makes sense on several levels. However his visuals (pics) do not give an example using the Sony CRX230EE CD-RW in question. It also does not demonstrate a clear explanation of the tray motor belt he mentions. I will demonstrate this much clearer as well as introduce another cause which involves the Tray Gear. The Tray Gear can have broken teeth, or be misaligned because of attempts to pry (or force) the Tray Door open by other means than it was designed (e.g., with a screwdriver).
Posted on Sep 07, 2014
    Sergeant:
    Champion:
  • 293 Answers
CD DRIVE DOOR WONT OPEN First Check the Data cables starting from the Motherboard then on the Drive Note on PIN1. It is suggested that a CD Drive should be slave to a Master HDD so set the Jumpers properly. If all are ok and still fails then the try the Emergency Eject hole. On many DVD drives there is a small hole on the front of the drive that is access to a manual eject mechanism. Use a straighten paperclip and insert it into the hole this will push the tray out. To repair this you need to change the Tray Motor Belt Look at this image >> http://an.hitchcock.org/repairfaq/REPAIR/whole/cd532s.gif For more Info on repair >>> http://www.repairfaq.org Hope this helps =============================================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
SOURCE:
I have just bought a sumsung external dvd writer se-so84c. Not only can I get any sound on playback dvd's although cd's seem ok, but also I am unable to record dvd's onto my sony vpcm12m1e which uses...
maybe your sound problem you can fixit with k-lite codec pack, download and install , you can use xp, vista . 7 etc, if cant burn use the last version of nero abalable
Aug 12, 2010 | Samsung Slim External DVD Writer Black ...
4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
Mar 23, 2010 | Husqvarna Designer I
CD is not recognised by the CD Drive
your dvd writer lens needs to be cleaned by a lens cleaner...
May 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
My acer m1640 is my first ever pc . i want to burn a cd
from the model number that you gave it shows that you have a burner. try going to were the music folder is at and right clicking with your mouse on the music and hit the send to option then select your cd rom as a destination then it will burn it this way as well. also make sure you have cd-rw disc dvd-r disc will not work for this
Jan 22, 2009 | Acer Aspire M1640 Refurbished Intel...
Dvd writer does not burn on raw file system cds
What OS are you using? I doubt it is the burner. I have the same model burner and it burns everything I try to burn just fine. It works on both my XP SP2 installation and the OS X86 Leopard 10.5.5 installation. I have burned video, data and bootable OS DVDs and CDs in both operating systems.
It may just be Nero. You could try Alcohol 120% or Ultra ISO.
Dec 27, 2008 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Can't update my new husqvarna diamond embroidery machine
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
Nov 24, 2008 | Husqvarna Designer I
SONY DVD RW AW-Q170A not working....
one reason may be that your writer may be old and the lense must have died.
another is that the lense require cleaning.
the last one is that you need to upgrade the drivers and firmware for your sony writer which you will get here.
http://sony.storagesupport.com/models/21
If all the above things dont work, replace it.
Jun 30, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
A slight hitch!!
hi change your data cable and try it.
or try to copy disk then if u burn the disk your cd writer ok.
change your nero soft u can download from here
http://www.brothersoft.com/downloads/nero-startsmart.html
Apr 02, 2008 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Cant read dvd on my sony 18x dual layer dvd writer
go to nero 6.66 and use imation discs, if your os is running ok and you do not suceed whith that i told you, your dvd unit is bad.
Mar 14, 2008 | Sony AW-Q170A-B2 BLACK 18X DOUBLE & DUAL...
I NEED A SOFEWARE FOR SONY DVD WRITER (VRD-VC20) BRAND
I have never use with computer. have connected to VCR and small television, and copy direct from vcr to VRDVC20 and have had no problems. I do have the soft ware disc, as bought mine new and have used only to copy video to CD and if follow directions exact, the will finalize - no problems.
[email protected]
Dec 01, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Open Questions:
Norton tEch SUpPoRt nUMber 1[=855=536=5666]==O Norton Antivirus CUsToMeR Service nUMber S%JaExW Norton CUsToMeR SUpPoRt [1=855=536=5666]O^ Want to get secured with the security software for the system? Get simple and easy to use security software for your PC. Make extra Firewall security for your system with the Norton Antivirus software. Improved Security for your Personal System and related devices. Safe & Secure your Login Details, Banking Credentials and much more. Log in to Norton Account online to get the best offer details and discounts on the same. Download Free Norton Secure line VPN for Windows, Mac, Android, and related devices. Norton Customer Support Number +1-855-536~5666. Norton software covers your files and folders with a layer of a lock so that your data is protected from viruses. Its filters out objectionable content and controls your system incoming and outgoing Wi-Fi networks. It is reliable security that protects the data of all Internet users. You will find many Norton antivirus products . If users have purchased the Norton product by visiting their official site, they will have to provide the activation code on their email ID to activate the Norton software. The incidence of data loss caused by viruses can be controlled with the advanced features of the Norton software. Thanks to their information technology innovation as they are continuously enhancing their features and security. While using antivirus, you may get errors that can affect your PC and documents. Use Norton Support Number to throw out errors from your antivirus. Norton is one of the best antivirus companies but due to the growing users of Norton, the issues are also increasing due to which we provide instant service for Norton Activation and installation. Norton installation error code 0 occurs when the installer displays a red banner and you receive a message stating Unable to continue installation.
Oct 14, 2019 | Norton Computers & Internet
BULLGUARD tech sUpport PhoNe~-18OO+8031069;; nUmber bullguard-svd BULLGUARD Tech support Number +1-8OO803-1069 to resolve all BULLGUARD products. BULLGUARD is an American multinational company which was founded by Michael BULLGUARD using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, BULLGUARD support number, and selling of computer-related services and products. BULLGUARD Tech support Phone Number Recently, BULLGUARD has been named the number BULLGUARD customernical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, BULLGUARD customer care number can be dialed to contact the certified customernicians Contact Customernical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a BULLGUARD Service Tag or a BULLGUARD Get BULLGUARD Customernical Support Phone Number and Customer Services. BULLGUARD is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization supports, repairs, sells, and develops customernology products. Basically, the company offers computer related products and services BULLGUARD Tech support Number +1-8OO803-1069 to resolve all BULLGUARD products. BULLGUARD Tech support Number +1-8OO803-1069 to resolve all BULLGUARD products. BULLGUARD Tech support Number +1-8OO803-1069 to resolve all BULLGUARD
Oct 14, 2019 | The Computers & Internet
See all Sony CRX230E CD-RW Burner Questions
Sony CRX230E CD-RW Burner Logo
228 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
