Question about Abit AG8 Motherboard
Black Screen(no boot up?)
I have installed everything correctly, i think. When i start up the computer all fans start up, and the motherboard number at the bottom right lights up with a number. But i have nothing showing up on the monitor...i have the graphics card in the forth slot down from the PCI-express expansion slot. I have a pci graphics card installed not a pci-express. If anyone can help me out i would appreciate it!!! Thank, Liljman1213
  • liljman1213 Sep 19, 2007
    Is there a way for me to have blown the CPU, by installing it? I made sure that i was grounded before i did anything on inside of the computer. Or is it that i did not install things correctly, this is my first build.
    Sergeant:
    Champion:
  • 293 Answers
MOTHERBOARDS Hi there try this, Check your memory if they are installed properly and that the contacts are clean and shinny. Chec the error code (Number) on your motherboards manual For More Info Visit your Motherboard's Hope this helps =============================================== If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
How do you fix a corrupted bios?
I don't think it's corrupt bios, maybe a virus or malware.
But if you can go to the computers maker website and download bios and install them the way they tell you to install them.
Feb 01, 2016 | Computers & Internet
Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
Check the hard drives, are they functional, do they boot with other computers?
Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
Hi to all i had an old dell gx270 and last week i pulled it all apart the motherboard the drives everything and i dont know why today i decided to fix it back and i did it well but when i turned it on...
It's overheating. Check the heatsink and fan. Make sure that it's not loose. Make sure the fan is plugged into the motherboard.
Make sure to put back that green shroud.
Sep 03, 2011 | Dell OptiPlex GX270 PC Desktop
Gateway GT5220 bios works no boot up
If the issue was the video card then there would be no display. If there was any display it would be discolored.
Try unplugging any removable media that's hooked up to the computer. After that try to boot it up.
If it still doesn't go anywhere then you most likely have a power supply issue on your hands. try unplugging an unnecessary components inside the computer such as any CD/DVD drives and removing any cards installed. Pretty much everything but the motherboard and the hard drive. If it still doesnt boot properly then you might either have to buy a new power supply or a new motherboard as long as you know your hard drive is good.
The thing si if it was an issue with the hard drive you would get an error message. If you seemed to have left out any error messages please post them.
Jun 07, 2010 | Computers & Internet
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
I tried to install Windows XP sp2 and the windows boot screen did not show up.
Reinstall and during the install press F6 when it ask if would like to install 3rd party drivers and have the driver disk for your hard drive ready and install those when ask.once it is done it should complete the xp install and restart correctly.
Jun 01, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computer freezes with black screen
check that all cables are securley fitted to your drives . try unistalling the graphics card , boot up the computer , if it boots up then you will need to install the drivers that came with the graphics card first
Jan 25, 2009 | MSI : 661FM-L P4 SIS661FX FSB800...
Bios don't boot at start stays at Black screen
i had a same problem too. but i know the real problem is the motherboard. it should be replace with the same model of motherboard.
Sep 18, 2008 | EliteGroup NFORCE 570 SLIT-A Motherboard
NO SCREEN DISPLAY WHEN BOOTING ON MSI MOTHERBOARD
first see pulg or correctly put
Then remove the fan and insert properly after completing then start the computer if u face again same problem i think fan is goan
Jul 31, 2008 | Intel Motherboard
D915GAG problem
this cant have anything to do with only replacing a cooler, unless when fitting it you have caused some sort of stress damage to the motherboard. Check all seatings of ram, graphics card and power connections in case they have been dislodged. I assume you have tried resetting the cmos settings in case there is a corrupt bios for some reason. The only other check is to see if the cooler is starting up straight away, as the processor may be shutting down if there is no fan running, or the motherboard is reading the temperatures incorrectly and not enabling you to boot.
May 09, 2007 | Intel D915GAG Motherboard
Abit AG8 Motherboard Logo
206 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
