Question about Car Audio & Video
Send me info how to connect a 4-channel car amp with 2 12-inch subs rear and 2 front 2-way speakers?
    Problem Solver:
  • 6 Answers
Plug two subs in to amp in most powerful channel then your speakers in the less powerfull take your positive from your battery and hook it to your amp your ground wire shud just touch a solid piece of metal take your remote wire and hook it to your deck all other wires shud be with your deck need n e thing else holla
Posted on Apr 19, 2009
2 ohm amp to 2 10 inch dual coil 4 ohm subs how does it need to be wired
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Apr 08, 2016 | Dual Car Audio & Video
Looking for info on how to hook up sub to this amp thunder4160
Hi, you have two choices for hooking up a sub to the 4160 amp. You can either connect your sub to one of the two available channels, or if the amp supports it, you can bridge channels 3 and 4 to get increased power to your sub. You have a 4 channel amp - channel 1 and 2 go to your 3-way speakers up front, which leaves channel 3 and 4 available for your sub.
Jul 27, 2013 | Car Audio & Video
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello i am rohit i have avh-6850 in my car i want how connect front and rear speaker and subwoofer there only two rc output one is front and other is non-fad & subwoofer tell how to connect front and...
If you only have 2 sets of pre-outs, you will either have to split the fronts into front and rear channels and use the other for a subwoofer signal, or else utilize an equalizer or other preamp that separates out a sub channel. I have an Alpine EQ that I send one stereo pair into, and it sends out front, rear, and sub outs. That allows for front/rear fade, and independent sub level adjustment.
Nov 08, 2010 | Car Audio & Video
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
I am trying to install my xtant 604x after i just had it sent out and repaired. I have 4 rca's coming from the head unit wired to the amp as FL, FR,RR,RL. The front speakers connected to the front output...
CLICK HERE for your Owners manual in PDF format
CLICK HERE for your Installation Guide in PDF format
As we agreed in chat - you are going to run your 4 channel amplifier as follows...
Front Channels of amplifier will run left and right independently.
Wire up the left speakers in parallel all + together and all - together.
This will yield a 2 Ohm load.
To the Same with the Right Side speakers - on the FRONT Right channel of the amplifier.
Now you have a 2ohm stereo load on the FRONT channels of your amplifier.
And using the BRIDGED nomenclature on the REAR channels of your amplifier - wire up your 4ohm sub mono.
Here is a crude drawing for a visual
Thanks for using FixYa - a 4 THUMB rating is appreciated.
Sep 05, 2009 | Car Audio & Video
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
132 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
