Question about Vizio L32 32 in. LCD HDTV
No Power TV power went off and won't come back on. My husband took it apart with no luck. Any suggestions?
You can directly go to the main power supply and then you test on the board,board which when the power supply is on,.,you check the IC if they have a supply of current past through..that's my solution for that's problem..
Posted on Sep 19, 2007
SOURCE:
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
Dec 01, 2014 | Sansui 50IN E-LED TV 1080P SLED5000
Lost all power in 1991 RCA TV model F35100ST
Best thing to start here is open up the TV and look for any blown components on the power board (which is the one that has the power cable attached to); check the transformer for continuity first, that is the first thing to blow. Then go on with capacitors, resisters, and any burnt wires.
All of these parts are easy to find and replace, they can be found in local electronics shops.
Please post back how it went and any further information or questions you may have, so we can help you better.
Dec 14, 2007 | Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Hi,I have a 7" under
How much? 7" under? good indeed.
Dec 26, 2017 | Coby KTF-DVD1093 10 in. Under Cabinet TV
My philips televison doesnt turn on Previously I would just unplug it and plug it back on and would turn on I believe that its the on/off switch that isnt working properly. The TV works it just cant be...
try this before you toss it...recently my magnavox 37" had been takign upwards to an hour to turn on. this past tuesday i check these threads to determine the problem. like many have said, its probably the capacitor, which it was n my case. basically i took everything apart and the bad (2) capacitors were obvious. one was oozing the electrolytic fluid and the top of the other started to 'dome' on the cap. i then went to a local electronics store (not radio shack, parts are too specific)... $3 for the (2) capacitors and a $20 solder iron. then you just de-solder the bad caps' and replace. i took the approach that - "what's the worse that could happen, the tv already didnt work?" well i just completed teh fix, it took about 3 hours and saved me nearly $300 that i didn't have. you can't be without your flatscreen at the beginning of football season!!!
gook luck
Sep 06, 2009 | Philips Magnavox 27MS343S 27" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
35 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
