Question about RCA Cable Modem DCM315R (11603540)
Bridge RCA Thomson DCM315R
I am trying to use remote desktop. My computer that I am trying to connect to has the setup of Cable Modem to the netgear router wired to my computer. I believe that I need to setup my cable modem to bridge to the router otherwise I think I am dealing with two different internal ip addresses and i believe it will confuse my system. I tried port forwarding from the router but It still doesn't find my computer. Any thoughts?
    Problem Solver:
  • 22 Answers
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
Note:
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Posted on Oct 25, 2007
6ya staff
SOURCE:
Can i connect a netgear JFS524 directly to acable modem
Yes for sure you can do that.As the connector is RJ45.The only think is that for Thomson you need a cross-wired cable to connect to the netgear JFS524. If netgear do have Uplink port then you can use normal or straight through cable.For more infor Cross-wired cable are use to connect between network devices.
Feb 25, 2015 | NetGear ProSafe JFS524 24Port Ethernet...
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
I need a replacement cd to add dcm315r to a new computer
download drivers here http://users.volja.net/pm5884/thomson.htm
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 30, 2010 | RCA Cable Modem DCM315R (11603540)
My RCA DCM315R keeps restarting
try downloading firefox from www.firefox.com and install that. See if you get the same issues. That will help isolate the issue.
May 25, 2009 | RCA DCM315R Modem
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Cable Modem DCM315R Problem:
Who is you service provider and do you have a router connected to it as well?
Oct 20, 2008 | RCA Cable Modem DCM315R (11603540)
Rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
RCA Cable Modem DCM315R (11603540) Logo
495 people viewed this question
Top RCA Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
