Question about Texas Instruments TI-89 Calculator
Will not turn on after i droped it, can i get it repaired?
My TI-89 calculator will no longer turn on after i droped it, is there any where in australia,melbourne to get it fixed?
  • Texas Instru... Master
  • 8,046 Answers
If it is not broken, the fall may have unseated the batteries. Jiggle them around a bit. It may solve problem.
Hope it helps.
Posted on Oct 01, 2009
How to un froze the TI-89 titanuim will not turn off.
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium
Feb 27, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
I couldn't turn my calculator all of a sudden. How can I fix this trouble? Can I send my TI 89 to the company and repair? Thanks
Don't send it in for repairs just yet.
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, press and hold the 2ND, left-arrow, and right-arrow keys, then press and release the ON key.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 21, 2010 | Texas Instruments TI-89 Calculator
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
Aug 01, 2010 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
My ti-89 titanium will not turn on, and i have replaced the batteries
Having received no response in over a month, I assume this is no longer a problem.
May 19, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium Battery use
I have a regular TI-89 (HW2)...have had it for 6 or 7 years. Suddenly it's doing the same thing. I have to put new batteries in it every week or so. I even replaced the backup Li-Ion battery. I'm getting really tired of buying new batteries but don't want to go shell out 100+ for a new one.
Anyone have anything on this? I'm having trouble finding much on this...
Oct 01, 2008 | Texas Instruments TI-89 Calculator
TI 89 problem
Try doing a hard reset (hold simultaneously Left + Right + 2nd + On). If it just isn't wanting to display properly, but does turn on, that might help. I think you can do the same thing by taking the four AAA's out and the spare CR1616/CR1620. Otherwise, the battery acid probably ate one of your components and it's time to repair/replace your handy-dandy.
Oct 26, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
194 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
