Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Dirty glass the inside of the glass is dirty. I cannot tell how to get the glass up to clean it.
  • Anonymous Oct 27, 2008
    Removing covers to repair scanner belt
  • 161 Answers
Taking that glass apart requires removal of almost all exterior covers. Not recommended to users without technical training. Any Samsung copier service center should be able to do it, since the unit is really made by Samsung as model SCX-4720f/fn.
Posted on Sep 22, 2007
SOURCE:
Remove glass door on kitchen aid stove, to clean
I'm wondering if you really need to remove the door to clean it. Just open the door and clean the inside of glass.
Jun 22, 2014 | Computers & Internet
The glass of my watch got all dirty from inside how do I clean it?
You may need to open it from back to get the inside of the dial. Then use a **DRY CLOTH** to gently wipe inside of the glass.
To play safe take help of a watch technician.
Nov 26, 2010 | Swatch Blustery
When I feed pages through the automatic feeder, the copies come out with a streak on them. If I put them directly on the glass it doesn't happen. I have cleaned the platen glass with no result.??
It is a cleaning issue. There is a piece of glass about an inch wide that is next to the platen glass or inside the auto document feeder that is probably dirty depending on your model. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 03, 2009 | Canon imageCLASS D320 Digital Copier
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 | Ovens
Need to clean the inside of glass on maytag's oven precision 500.
I have a GE range. The oven has a glass window. There are an inside and an outside glass. Somehow the inside of the two glases has gotten dirty. How can I clean this? Can I take the door apart? Thanks
Apr 25, 2009 | Ovens
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning glass dirty
hi,
not to worry... u can clean it with a lint free cloth.
thanks and regards
agnel
Dec 28, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP 6110 All-In-One Printer
there should be two screws on the right side of where the glass, take them out, some models you also have to take the screws off of the left side since it is one piece, lift the whole unit With the glass and set aside to clean. ( With power off)
Oct 21, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
