Question about Samsung DVD-VR330 VCR and DVD Recorder
Unit won't work
It displays SAFE and nothing works.
Right solution - Wrong button. It is the INFO button just below the navigation circle on the remote..
AND - I finally found it in the manual after looking in all the wrong places for several hours. On page 13 (Tour of the Remote Control) there is a big grey box in the lower right corner titled "Key Lock Function". You guessed it.
Posted on Oct 24, 2007
Using the remote, press "display/input" button for 10 sec, to unlock the unit.
Posted on Oct 23, 2007
  • Pacho Oct 27, 2007
    Next time you have a problem with a Samsung product I suggest you call Samsung Customer Service 1-8700-SAMSUNG. They are very helpful and are open 24-hrs.
    The phone is 1-800-SAMSUNG.
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
Radio has stopped working, but the panel on the radio stays lit in red when the car is turned off,( the little light items on the radio which would normally go on when the lights are turned on. it is an...
For Audi A6 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
The fuse for the radio is no.# 37 fuse: F37 (20A - yellow colour). See picture below:
There is a second fuse on the back of the radio, (10A - red colour), but you have to pull the unit to check & change it. This is only course of action. You need special Audi radio extracting tools, (two radio keys).
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Aug 29, 2010 | 2002 Audi A6
Need to unlock child lock
Child Lock
The control buttons on the front of the unit can be
switched off so that your unit can only be operated using
the remote control.
1Press C.LOCK.
and SAFE will appear in the display window.
None of the buttons on the front of your unit will
If any buttons on the front of your unit are pressed
SAFE will flicker in the display window for a few
2Press C.LOCK again to switch off the child lock.
OFF will appear in the display window.
– C.LOCK is not available on the DVD mode.
Oct 28, 2009 | Philips DVP721VR DVD Player/VCR
Front display says "SAFE" and now nothing works
hold "info" button for ten seconds
Oct 02, 2008 | Samsung DVD-R135
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Unit in "safe" mode
Try pressing the stop button the front panel of the unit and holding it in for 5-10 seconds.
you may also want to try it on the remote.
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Oct 29, 2007 | GoVideo DV2150 DVD Player/VCR
Greetings Spock! Although I worked for an authorized rca service depot for 12 years, and worked on many, I can't remember the solution to your problem, and Thompson Consumer Electronics (RCA/GE) don't even accknowledge they ever sold vcr's..I went to and your model comes up as "does not exist"...Anyway...I know I've worked on that model, and if you have the book, check the section about parental lock, or Key lock...your RCA could very well be Samsung inside, and if so press and hold the tv/vcr button for 5 seconds and that will release the key lock feature. It is there so if you set the timer, or just don't want the kids messing with it, you can lock all the key functions, and the unit will do nothing except display "safe" Hope this helps...Live long & prosper!
May 03, 2007 | RCA VR557 VHS VCR
Samsung DVD-VR330 VCR and DVD Recorder Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
