Question about SanDisk Sansa e260 MP3 Player
My sansae260 lost its memory
I plugged in my sansa into the computer and it erased everything except on my memory card. then when i checked on the info it said i diidnt have any memory except on my memory card. i lost 4 gb from my mp3 player!
    President:
  • SanDisk Expert
  • 650 Answers
Remove the card and connect to the computer go to my computer and right click on sansa click format do what it says then try and load your media on it to delete your card put the sansa in msc usb mode and connect you will see the card under my computer format that too if you want to
Posted on Apr 19, 2009
I have sansa clip 2gb. I reset it completely. When I turn it on again i find the same settings again. Ive tried everything every kind of formatting but its setting wont change nor the data on it could be...
Plug it into your computer via USB, then copy the files over. Make sure you are formatting the memory card, and not the camera's internal memory. As a side note, formatting the card will not reset the settigns, and resetting the settings will not format the memory card
Mar 08, 2011 | Cameras
Freezes on SanDisk Sansa screen
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Memory card isn't reading correctly
-Tha Mp3 Doctor
Jul 21, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do you erase the memory card?
You can format in the camera. usually you go to the menu on your camera and select tools or utilities, select format.
Your memory card will be erased.
Jun 23, 2008 | Olympus FE-230 Digital Camera
Memory problems
omg - The songs you are trying to load are probably in the wrong format - see my "tips and Tricks" on mp3 player song format - it is a 2-part article
-Tha Mp3 Doctor
May 31, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa c200 displays "Memory full, free some memory" and doesn't function
Player needs to be reformatted - checked my "tips and tricks" on Reformatting
-Tha Mp3 Doctor
May 27, 2008 | SanDisk Sansa c200 MP3 Player
Memory troubles
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 280e internal memory change to e260 internal memory
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Dec 17, 2007 | SanDisk Sansa E280 MP3 Player
Unit not recognised by my computer or any other, and memory issues on another unit.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
