Question about Honeywell HZ365 Ceramic Compact Heater
Heater kicks out
I have a Honeywell heater, model # HZ3650. The problem I have is that the heater runs for approx" 1-5 minutes and then kicks out& it would not run again. Then the next day while playing with the heater it did start, but did kick out again and will not re start, even when given time to cool down. what is the problem?
  • 3 more comments
  • Tentwo Oct 16, 2007
    Thanks.
    Connections did not seem loose, but since I have had them off and reconnected it has been fine.
    Thank you for the help.
  • MRFIXITRIGHT Jan 26, 2008
    stays on for only a short time, then off it goes untill it cools down and also is unpluged.
  • Anonymous Apr 11, 2008
    First posting here, this was meant to be a 'problem' not a solution as below, apologies...
    I live in a basement suite which seems to get quite cold in the winter, and this little fella puts out heat just fine, but turns itself off and will stay off until unplugged for a time - however, during this time, the room cools off too much and so it becomes a constant waiting game of the unit thinking it is 'too hot to start' and unplugging.. any suggestions or alternate products I could look at?
    Thanks in advance for any ideas.
  • Anonymous Oct 28, 2008
    I have the exact same problem. You can let it cool for days, but unless you unplug it and wait a little longer, it won't start up again. While unplugged, it makes a tick sound, and after that it will start again (for a short few seconds to a minute.)
    Is there a part that can be fixed or replaced?
  • Anonymous Mar 17, 2014
    model #r60 heater starts and runs about 1 minute than stops unplg and replg in and starts again have not replaced anything
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Posted on Aug 17, 2008
Follow-Up Question from another buyer of this product:
Posted on Apr 11, 2008
  • 625 Answers
Loose connection to the thermostat. if the unit uses push on spade connectors, there could be sparking at the connection which expands the metal so it doesn't make contact. cooling down it makes contact again.
Posted on Sep 24, 2007
SOURCE:
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Need to set differential on my ct 1540 thermostat, the furnace kicks on at after it drops 1 degree this cant be right
Yes this is probably correct the newer thermostats will kick on with a 1 degree temerature drop. This is better since the furnace only has to make up one degree of temerature and has a shorter run cycle saving you money.
Dec 24, 2009 | Honeywell CT3600 7 Day Electronic...
My honeywell t-stat reaches current temp setting and furnace kicks off...but within 1 minute the t-stat drops 1 degree and the freakin furnace kicks on! This can't be right as it has never happened with...
Your differential is set to close you can go into tstat and change differential setting. Your install manual for your thermostat will tell you how you can set 1.2.3 degrees differential
Dec 13, 2009 | Honeywell Electronic Programmable...
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Heater unit kicks out GFI
most require a seperate circuit for the heater. depending on HP on the circulation pump and wattage on heater.
Nov 30, 2008 | Home
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell HZ365 Ceramic Compact Heater Logo
488 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
